22754 Discussions
A380 no hdmi or dp output
bobr1
I'm running windows 11 pro 22H2 with all the latest patches. I downloaded and installed successfully 31.0.101.3802 of the arc driver.
Installation went fine and I can run graphics dependent workloads on it remotely using parsec and its able to fully leverage the GPU.
There are no errors on the system drivers look healthy and using the Intel Driver Support Assistant it says everything is great.
Yet no matter what I try I get zero output on te hdmi or display ports. When I try to manage the display properties it says I can't do that remotely.... I'm a linux guy and very rarely use windows so any help on logs to look for or driver options i should be using would be appreciated. This is the first windows install I've had since Windows 7. So I'm a fish out of water.
Oh and the outputs work fine under arch linux.
Bob
