20675 Discussions
ASRock Q1900TM-ITX - Sporadic no output on hdmi
CSchi4
Hello community,
with the following configuration I get sporadically no output on hdmi:
ASRock Q1900TM-ITX with Intel J1900 CPU
Intel 7th. Gen Graphics
16GB DDR3 RAM
120GB OCZ Vertex 2 SSD
Microsoft Windows 10 x64
Graphics driver: 15.33.38.64.4252 from 07/29/15
When the system boots up, I can see bios-logo and windows bootlogo over hdmi. When it comes to windows, there is only output via vga.
When I connect a vga cable, it works fine, but picture is pretty bad on my display. When I connect both cables before I start my system,
output is still on hdmi. When I shutdown windows and disconnect vga, it could work on hdmi, but thats only a temp solution, since on
a new boot, it could be changed again. There is no pattern, so that I could say "when I do this, or that, it fails, or it works"
Should I change my Windows version, or is there a solution? (Maybe to disable the vga-output!?)
Thanks in advanced
Chris
