22949 Discussions
ASUS Taichi21 and a Displaylink Dock
SPica
I am reposting this here. Trying to get it out as much as possible.
This is
what I received from ASUS Support.
"I just got a reply , and for the
TAICHI21, it does not support any dock station, it means there is a
compatibility issue between the TAICHi21 and the HZ-1 dock, so it is not only a
driver issue. You had better not connect the dock to the TAICHI21 for usage. And
our engineer won't develop any new driver for this issue. Sorry if any
inconvenience this case.
Kylin_lu
ASUS Product
Support Team"
as a note the "HZ-1" uses the DisplayLink driver just like
all the docks out there.
Kevin_M_Intel
Hi picardsm,
Can you please post your dxdiag report here?
SPica
That would require me to install the driver again, wouldn't it?
Kevin_M_Intel
You posted the response from other tech support but honestly I am not sure what type of assistance you are looking with Intel®. If you can explain more about your issue and post the dxdiag report with all drivers install in your system will be very helpful.
