22772 Discussions
AYUDA no puedo instalar el controlador de graficos i3 8100.
CCorr2
HOLA TENGO UN PROBLEMA CON EL CONTROLADOR DE GRÁFICOS DE ESTE PROCESADOR NO PUEDO COMPLETAR LA INSTALACIÓN TODAS LAS DESCARGAS NINGUNA ES CORRECTA ME DICE QUE NO ES COMPATIBLE CON EL PROCESADOR... CUANDO LA DESCARGA ES REALIZADA DESDE EL ASISTENTE DE INTEL. NECESITO AYUDA YA NO SE QUE PROBAR
Hello christiancorradoARG
Thank you for posting in the Intel® community.
  • Have you tried a manual installation of the graphics driver? See the steps below.
  • What is the brand and model of your system (laptop or motherboard)?
  • Steps to complete manual installation:
  • Please follow these steps in order to update the graphics driver:
  1. Download the graphics driver ZIP file: https://downloadmirror.intel.com/28240/a08/win64_25.20.100.6326.zip https://downloadmirror.intel.com/28240/a08/win64_25.20.100.6326.zip (lasted version)
  2. Unzip the file to a designated location or folder.
  3. Right-click Windows Start icon and open Device Manager.
  4. Click "Yes" when prompted for permission from User Account Control.
  5. Expand the Display adapters section.
  6. Right-click the Intel® graphics entry and select Update Driver Software.
  7. Click "Browse my computer for driver software".
  8. Click "Let me pick from a list of device drivers on my computer".
  9. Click "Have Disk".
  10. Click "Browse".
  11. Access the designated location or folder, and access a folder called "Graphics".
  12. Select the file called "igdlh64" or "igdlh".
  13. Click Open, then click OK, and finally click "Next". Drivers are now being installed.
  14. Reboot your computer.
Hope this helps.
Leonardo C.
  10. Click "Browse".
Hope this helps.
Leonardo C.
CCorr2
PROBLEMA RESUELTO... ACTUALISE WINDOWS 10 A LA ULTIMA VERSION Y PUDE ACTUALIZXAR EL CONTROLADOR COMO ESTA EXPLICADO ARRIBA
mariobrena
yo tengo el mismo problema. no encuentro los drivers para i3 8100. Yo quiero instalarlos en windows 8.1 de 64 bits. Yo se que Microsoft ya no da soporte a 8.1 y tenemos que actualizar a 10 o a la version 11 pero no entiendo porque ustedes se someten a Microsoft. Ustedes deberian de continuar dejando en su pagina web los drivers para todas las versiones. Como puedo instalar los drivers que necesito sin tener que actualizar a windows 10 o windows 11. Gracias
