23838 Discussions
About Intel Compute Stick STK1AW32SC
BmjlGenhao2
最近我将Intel Compute Stick STK1AW32SC 重新安装了操作系统,但当我寻找驱动时,却只能找到无线网卡和蓝牙的驱动程序,而没有Atom x5-z8330中的Intel HD Graphics驱动程序。
当我前往下载中心寻找时,找到了适用于Cherry Trail的驱动程序,版本20.19.15.5171.但我运行安装程序时,提示“此计算机不符合安装该软件的最低要求”。因此无法安装图形驱动程序。
据我所知,下载中心中已经不再提供STK1AW32SC的驱动程序,我希望可以获得相关支持,使我重新安装图形驱动程序。
Recently, I reinstalled the operating system of Intel Compute Stick STK1AW32SC, but when I was looking for the driver, I could only find the wireless network card and Bluetooth driver, not the Intel HD Graphics in Atom x5-z8330 driver.
When I went to the download center to look for it, I found the driver for Cherry Trail, version 20.19.15.5171. But when I run the installer, it prompts "This computer does not meet the minimum requirements for installing the software". Therefore, the graphics driver cannot be installed.
As far as I know, the driver of STK1AW32SC is no longer available in the download center. I hope to get relevant support so that I can reinstall the graphics driver.
n_scott_pearson
According to my records, it is the 15.40.41.5058 package (driver 20.19.15.5058) that you want. I have placed a copy of the pertinent files onto a share (here: https://1drv.ms/f/s!AtacZBU04mo-kKYC-ZscC-c2BlQKiQ). The files you want are in subfolder STK1A32SC.
Hope this helps,
TryingHuman
Hi, is there any chance you could put those files again via the link you provided before? The STK1AW32SC subfolder doesn't appear to be there anymore.
I have the same device and for the life of me I can't find anywhere that has the SoC driver for the STK1AW32SC.
BmjlGenhao2
非常感谢你提供的帮助!但是问题似乎未解决,在我安装时,他仍提示“此计算机不符合安装该软件的最低要求”,我在Windows设备管理器中查找,发现Windwos并未识别HD Graphics。或许是缺少Chipset驱动或System-On-a-Chip驱动?
我尝试了ASUS VivoStick TS10所提供的Chipset驱动,图形问题能够成功解决,但此时我的Compute Stick没有了网络连接,这说明ASUS的Chipset驱动并不和STK1AW32SC完美兼容。
由此可知,提示“此计算机不符合安装该软件的最低要求”的原因是Chipset驱动的缺失导致安装程序无法找到HD Graphics。我已经在Download Center中寻找过SoC驱动,但并未找到。所以,能否请你再提供一下Chipset或System-On-a-Chip驱动?如果可以,请提供STK1A32SC为Windows10 64-bit准备的驱动,而非STK1AW32SC 32-bit的。
抱歉花费你的时间。
Thank you so much for your previous help! However, the issue persists. During my installation, it still prompts "This computer does not meet the minimum requirements to install this software." When checking Windows Device Manager, I noticed Windows failed to recognize the HD Graphics. This might be due to missing Chipset drivers or System-On-a-Chip drivers.
I tried installing the Chipset driver provided for the ASUS VivoStick TS10, which resolved the graphics issue, but afterward, my Compute Stick lost network connectivity. This indicates incompatibility between the ASUS Chipset driver and the STK1AW32SC device.
From this, it appears the error message "This computer does not meet the minimum requirements to install this software" stems from the installation program failing to detect HD Graphics due to missing Chipset drivers. I have searched for the SoC driver in the Download Center, but I haven't found it.Could you please provide compatible Chipset drivers or System-On-a-Chip drivers specifically for the STK1AW32SC?If possible, please provide the driver for STK1A32SC for Windows10 64-bit, not the STK1AW32SC 32-bit.
I apologize for taking up your time with this persistent issue.
n_scott_pearson
Oops, I think this was caught in my share cleanup. Anyway, I've recreated this subfolder.
Let me know of you have any issues,
TryingHuman
Thank you so much. I spend 8 hours debugging why the wifi wasn't working with a Cherry Trail_T SoC driver before I realised the problem. These ICS drivers are as rare as hen's teeth.
I think that other guy wanted the STK1A32SC 32-bit version. I jumped his thread.
Thank you again for helping me bring back life to this old piece of hardware.
