23854 Discussions
Accelerator Driver issues
KCoop
I keep getting the balloon that says
/message/224441# 224441 Display driver Intel graphics accelerator drivers for windows Vista(R) stopped responding and has successfully recovered fix ?
1st off I am running windows 7 I have tried everything from here and still not fixed...
Help pls
Silvia_L_Intel1
Hello KimmyC1971, thanks for joining the Intel Graphics Community.
I would like to know if you already tried all the troubleshooting provided by Allan in the thread you mentioned.
Also, Could you please attach the DX Diag report from your system?
(Start -> Run -> dxdiag -> Save All Information).
KCoop
KCoop
Silvia_L_Intel1
KimmyC1971, this seems to be an issue related to the operating system, since you are using Windows 7 and the error you are getting is mentioning Windows Vista.
According to the DX Diag report you attached, you are using the latest driver available for your system. I would recommend you to try doing a system restore or you will need to reinstall the operating system.
KCoop
Okie Dokie... I will get back to you after I do the re-install... Thanks
