I had Aspire C27-1655 as my computer for some years now and among other used it to view my Network video recorder with EseeCloud program.
Now I bought a new computer an Aspire C27-195ES and for quite a surprise I cant see the live preview of the Eseecloud on this new computer. Everything else works. I can use PTZ for moving cameras, I can hear sound from cameras, so this is probably not an network issue.
I didnt believe the hardware and display driver could be so bad it cant do this so I did some test to figure out what the problem could be.
Tried “repair” windows with sfc/scannow and dism but no luck. Tried to uninstall and install display drivers, DDU and so – no luck. I have pair of harddrives so I tried to install a fresh windows 11 - and windows 10 . . . no luck
The stream disappears somewhere between networkadapter and display. With wireshark I can see TCP and websocket trafic from NVR to computer.
The graphics is integrated in core ultra5 125u
Hello RRuo58,
- How did you connect the cameras to your laptop?
- When you changed the laptop, your are already having this issue and when you connect the old laptop, everything is working fine?
- Can you also share to us how did you connect the cameras with the old laptop?
Michael L.
1. Cameras are connected to Network Video Recorder that is on my home WLAN. My Acer AIO desktop is on that same wlan.
2. Connection to the NVR is still working with my old Acer AIO and I can also see the live preview on my 300€ android device thru that same wlan. The only device that is NOT showing live preview is my new 1000€ pc.
Hello RRuo58,
Thank you for the update.
Upon checking, you are using an older Graphics driver which is 32.0.101.6737.
The latest that we have right now is version 32.0.101.6790.
Kindly update the driver using DDU method, kindly refer to the link below for the link of the latest driver and steps to follow DDU.
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
If you are still having the same issue, kindly generate a new set of SSU logs for me to have this issue checked.
Michael L.
Updated the driver using DDU in failsafe mode and installed the new driver. Did not change anything
Picture showing old computer via tightvnc and eseecloud running on new computer.
Hello RRuo58,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Hello RRuo58,
I just want to update you that we are now looking into this issue. However, we have some questions. Please help provide the following details:
- We want to clarify who provided the screenshot, there are two windows visible. One window displays the output, while the other is just loading and shows a black screen. Does this mean that only certain windows are functioning correctly? Is that accurate?
- Have you tried reaching out to EseeCloud technical support? They may have several troubleshooting steps available, and we are not yet certain if the issue is related to graphics or WiFi connection. Here's the article we found: https://eseecloud.app/frequently-asked-questions/
- Please update the wireless and graphics drivers using the OEM website. Here is the link: https://www.acer.com/us-en/support/product-support/C27-195ES
- Did you also tried to contacted HP regarding this issue?
Michael L.
Picture is taken from my new computer display showing the old computer running eseecloud seen via TightVNC viewer and eseecloud program running on my new computer at the same time.
I have been trying to troubleshoot this problem for a while now installing and uninstalling drivers and installing windows versions. Tried network connections with wifi, disabling wifi and connecting my computer to router with ethernet cable.
Asked questions on Acer forum and Microsoft but have all ready tried uninstalling and installing drivers and tried fsc/scannow and dism and installed fresh windows 11 installing OEM drivers from Acer website.
Tried googling internet but found nothing I have not yet tried. Have read eseecloud frequently asked questions.
If this issue could be solved by uninstalling and installing drivers I believe it would have already been solved. I think this is some new feature either in windows or intel driver software.
Must try to ask eseecloud about this, but will probably get “uninstall-install-drivers”. . .
4. Not tried to contact HP because do not understand why? This is an ACER computer.
Thank you for listening to my useless rant about this issue that cant be solved – should not have bought a new computer.
Hello RRuo58,
We are trying to help you also or at least direct you to the correct support.
One thing that we are also trying to figure out is since the display is connected to the Wi-Fi, it should be the Wi-fi or the decoder of the program that is now transferring the display. That is why we also asked if you tried contacting the support of the program if they is a known issue.
Michael L.
Hi @RRuo58,
I hope this message finds you well. I am writing to you on behalf of Mike_Intel to sincerely apologize for overlooking the computer brand and model you provided during our previous interaction. I understand the importance of accurate communication and regret any inconvenience this may have caused.
I am currently investigating the issue you cited with the Aspire C27-195ES. As this is an OEM device, I will do my best to assist you with general troubleshooting steps, even if it falls outside the traditional scope of our support. However, if the issue persists, I will recommend contacting the Original Equipment Manufacturer (OEM) of your device. The manufacturer may have altered features, incorporated customizations, or made other changes to some components for better compatibility with your system.
Since you are reporting a CCTV software, working to troubleshoot the issue may contain personal information which can't be shared publicly. I'll contact you via email to discuss the potential troubleshooting first via email before we post here in the community.
Would it be possible for you to send the following so I can further investigate the issue:
- SSU scan of the Aspire C27-1655? I'll be using it as a point of comparison with the SSU log you've provided for the Aspire C27-195ES.
- Software wise, I'll need to obtain the links directly from you so that we can have the exact software that you're using to further investigate the issue.: - Can you share the system requirements needed to run the application EseeCloud?
- Can you share the download link where you can download EseeCloud?
- What is the software version of the EseeCloud app that you are using?
- I understand your apprehension in communicating with EseeCloud cloud support, it would be best to know if they have any reported issue similar to what you've encountered while utilizing the integrated graphics driver from Intel® Core™ Ultra processors (Series 1) or if this is an isolated issue? additionally, the can provide any work arounds for this issue.
Ernesto C.
Have download newest version from this link
On the old computer I use previous version 3.0.7.2 that I had also tried on my new computer and it behaves same.
Emailed eseecloud tecnical support, but they have not replied yet. In fact You are only who had payed any attention to my rant.
At Microsoft and Acer forums have only got "uninstall-install".
Thank You for your kind help, but more and more I start to believe this is just an new windows feature
Hi @RRuo58,
Thank you for quickly reverting to my message. I'll wait for your feedback if the eseecloud tecnical support provides any assistance or information on the issue. In parallel to your efforts, I'll be investigating the issue on my end as well and will provide you an update as soon as possible.
However, I need to set your expectation that Intel Customer Support does not have any CCTV camera on hand for simulation but I'll try to work around that limitation.
Ernesto C.
Tried fresh installation of windows 11 on the old computer. Did not change anything. It still shows the eseecloud live view without problem. In the old computer there is also a Nvidia GeForce MX330 so tried to disable it but no changes.
The eseecloud requirements for promgram is
Latest OS: Make sure you're running the latest version—either Windows 7 SP1 or Windows 8.1 Update. ...
Processor: 1 gigahertz (GHz) or faster processor or SoC.
RAM: 1 gigabyte (GB) for 32-bit or 2 GB for 64-bit.
Hard disk space: 16 GB for 32-bit OS or 20 GB for 64-bit OS.
Called Acer tecnical support and they said drivers should be downloaded from device manufacturer. They dont do any "modifications" because it would only lead to troubles.
Hi @RRuo58,
I'll shift my message via email since the questions I'll raise would be related to your CCTV setup.
This information should not be disclosed publicly.
Ernesto C.
I am now using version 3.0.8.4 on both computers. By my understanding it is the newest version.
I do not know if Eseecloud uses DirectX. I think it uses OpenGL.
I have four cameras connected to network video recorder. It is connected with ethernet cable to router for internet connection needed for cloud services.
I use wlan or ethernet connection to the router to connect to NVR. Very basic installation.
Have not used browser after flash player was banned. Moved to eseecloud.
Hi @RRuo58,
Thank you for your prompt response. I appreciate the information you provided, and I will use it to further investigate the issue. I will keep you updated and get back to you as soon as possible.
Ernesto C.
Hi @RRuo58,
Thank you for your patience while I'm investigating the issue with Eseecloud. May I know if you have tried to temporary disable the NVIDIA GPU form the old customer (thru the device manager) then try to open the application. I need to clarify this to know if the issue is present in the iGPU of the old computer as well.
Also, I would like to know if the eseecloud technical support team has responded to your email. May I know if they have provided additional information on the issue from their investigation?
Ernesto C.
I have tried disabling Nvidia GPU thru the device manager. It does not change anything on the old computer.
Eseecloud techical support has not responded. Tried sending another email to them but got yet no respond.
At microsoft community one other had same kind of problem with eseecloud, but there nobody really do not seem to have any kind of interest on this issue.
Thank You for your effort on this problem
Raimo
Hi @RRuo58,
Thank you for quickly responding to my previous message. Allow me time to investigate the issue further using the information you've shared.
I'll provide an update as soon as possible.
Ernesto C.
This issue is resolved. New version 32.0.101.8132 of the driver now works fine.
Big Thanks to every one working on this issue
Raimo
