22872 Discussions
Add monitor scaling options!
asabovesobelow
Could you please add these settings to UHD750, 770 etc graphics?
DeividA_Intel
Hello asabovesobelow,
Thank you for posting on the Intel® communities. I understand that you have a request for our Intel Graphics.
Based on your pictures, you are using the Nvidia control panel and not an Intel tool. Do you see the same behavior while using the Intel® Graphics Command Center (Intel® GCC) or the Intel® Arc™ Control Software?
I recommend you check with Nvidia to confirm if they can add more scaling options to their tool. You can see more information in the following article:
Deivid A.
asabovesobelow
sorry for bad explanation but it was just an example what i want to see in intel control panel, maybe you can make some update on drivers with these features?
DeividA_Intel
Thanks for the declaration. I will gather the info that you provided and send it to the team in charge so they can have it under consideration for future releases. However, I cannot promise anything.
I will proceed to close this thread, but you can open a new one in case you need support.
Bear in mind that when using the Recommended Screen Resolution for the selected display, only Maintain Display Scaling will be visible. The Custom scaling option will also be available to correct overscan.
The remaining scaling options (Centered, Stretched, and Maintain Aspect Ratio) will be revealed when a screen resolution different than the maximum supported resolution or recommended for the selected display is selected.
Deivid A.
