23069 Discussions
Adobe Lightroom crashes due to module error ig7icd64.dll, versie: 10.18.10.4653. Seems that this is the latest compatible version. CPU:Intel(r) Celeron(R) cpu N2920 1,86Ghz. Any idea or can someone help?
WVelg
Hello Pacopico,
I understand Adobe* Photoshop Lightroom is crashing in your computer.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Has the application worked fine before? In case the application has worked fine before, was there any software or hardware change before the issue started happening?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
WVelg
Hello Fred D.,
This was a new and first installation of Photoshop Lightroom on this PC. In meantime I have veryfied and run the updates of Lightroom.
Now the application is starting and working fine.
Thanks for your reply and cooperation.
Hello Pacopico,
I am glad to hear the issue has been fixed. Do not hesitate to contact us back if you have any other inquiry.
Fred D.
