- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Support-Team,
Forza Horizon 3 crashes after start on Intel Gen9 Graphics.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Game crashes directly after start
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Intel NUC6i7KYK
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)XXXWHIT...
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Looks like the developer was bored and gave all files random names (compared to APEX).
Min. specs can be found in targethardwareprofiler.xml which has been renamed to 1l4{q1@l46ml4qu4hv$bq4.]gb
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thank you for filling out the form, I have noticed that driver version 4541 seems Microsoft* customized driver.
I would recommend testing the Intel® NUC with driver version https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- 4501 or beta driver https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- 4539
Please report back with http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html graphics report of the driver loaded and the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® SSU
Allan.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Stefan3D: I don't get what you mean ^^
@Allan: Thanks for the reply. Sadly the same behavior with Beta v4539. Attached the reports with v4539 driver.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thank you for the reports, I have forwarded this information to the appropriate support team.
Allan.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Meanwhile I tested the new 21.20.16.4542 driver => The game still doesn't work
But Dota 2 got a nice performance boost
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
This message was posted by Intel Corporation on behalf of
Thank you for the update Loeschzwerg
Unfortunately, Forza Horizon 3 launch crash is an application issue where the application does not correctly implement the gpu detect code for Intel integrated graphics. As such, it does not detect the amount of VRAM available on our integrated graphics.
It is up to the game developer to provide a patch to fix the issue. They seem to be working on it and hopefully they will release a patch soon in the coming months. If we come across anything, we will keep you posted.
Here are some links available to game developers to correctly detect Intel Integrated graphics -
https://software.intel.com/en-us/articles/intel-graphics-developers-guides https://software.intel.com/en-us/articles/intel-graphics-developers-guides
https://software.intel.com/en-us/articles/6th-gen-graphics-api-dev-guide https://software.intel.com/en-us/articles/6th-gen-graphics-api-dev-guide
https://software.intel.com/en-us/articles/gpu-detect-sample https://software.intel.com/en-us/articles/gpu-detect-sample
https://github.com/GameTechDev/gpudetect https://github.com/GameTechDev/gpudetect
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Benlehot
Please check with the game developer regarding any updates to the game. Intel graphics fully supports the game but the game developer does not include support for integrated graphics. As always, if we hear from the game developer, we will provide update.
Thank you
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I sent 3 messages so far on their message board and no one is answering me
http://forums.forzamotorsport.net/turn10_postsm631128_Is-support-for-Intel-IRIS-gpu-coming.aspx Is support for Intel IRIS gpu coming? - Forza Horizon 3 Support -- PC - Forza Motorsport Forums
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I think Forza Horizon 3 is playable on Intel HD Graphics. But Microsoft restrict this game to run only on other than Intel HD Graphics chip.
YES It is the matter of fact that it requires higher Graphics chip to run without shutter.
I play GTA V at 35 frame per second at low graphics.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
It's all water under the bridge now. Now we can still wait a few days for https://forzamotorsport.net/en-us/news/fm7_gamescom Forza Motorsport 7
- Support for a Broad Range of PC Setups – Forza Motorsport 7 was designed to run smoothly across a wide range of Windows 10 PCs and performance settings. Not only have we lowered our minimum specifications to i5-750, we've also reduced our recommended specifications while still having the game run at a rock solid 60 frames per second. Even gamers with a Surface Book 4 or other budget-friendly gaming PC can play the game.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
JohnApex schrieb:
Forza Motorsports: 7 does not seems interesting as Forza Horizon: 3. But 'll try out this game. When it will out on internet?
Demo has been released: https://www.microsoft.com/en-US/store/p/forza-motorsport-7-demo/9P2XH29364LH?rtc=1 Forza Motorsport 7 Demo - Microsoft Store
Unsurprisingly it doesn't run on ye olde Broadwell.
I tried to sneak a peek at c:\WindowsApps\Microsoft.ForzaMotorsport7Demo_1.105.697.2_x64__8wekyb3d8bbwe\media\base\targethardwareprofiler.xml, but it is unreadable even with TakeOwnershipEx
