22663 Обсуждение
Forza Horizion 3 // Crash on Intel Gen9 Graphics
Loeschzwerg
Новый участник I
8 607Просмотр.
Hi Support-Team,
Forza Horizon 3 crashes after start on Intel Gen9 Graphics.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Game crashes directly after start
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Intel NUC6i7KYK
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
XXXWHIT...
0 баллов
14 Ответы
Stefan3D
Почетный участник II
6 134Просмотр.
Looks like the developer was bored and gave all files random names (compared to APEX).
Min. specs can be found in targethardwareprofiler.xml which has been renamed to 1l4{q1@l46ml4qu4hv$bq4.]gb
Сотрудник
6 134Просмотр.
Thank you for filling out the form, I have noticed that driver version 4541 seems Microsoft* customized driver.
I would recommend testing the Intel® NUC with driver version https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- 4501 or beta driver https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- 4539
Please report back with http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html graphics report of the driver loaded and the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® SSU
Allan.
Loeschzwerg
Новый участник I
6 135Просмотр.
Stefan3D: I don't get what you mean ^^
@Allan: Thanks for the reply. Sadly the same behavior with Beta v4539. Attached the reports with v4539 driver.
Сотрудник
6 135Просмотр.
Thank you for the reports, I have forwarded this information to the appropriate support team.
Allan.
Loeschzwerg
Новый участник I
6 135Просмотр.
Meanwhile I tested the new 21.20.16.4542 driver => The game still doesn't work
But Dota 2 got a nice performance boost
PradeepNar_R_Intel
Сотрудник
6 135Просмотр.
This message was posted by Intel Corporation on behalf of
Thank you for the update Loeschzwerg
Unfortunately, Forza Horizon 3 launch crash is an application issue where the application does not correctly implement the gpu detect code for Intel integrated graphics. As such, it does not detect the amount of VRAM available on our integrated graphics.
It is up to the game developer to provide a patch to fix the issue. They seem to be working on it and hopefully they will release a patch soon in the coming months. If we come across anything, we will keep you posted.
Here are some links available to game developers to correctly detect Intel Integrated graphics -
https://software.intel.com/en-us/articles/intel-graphics-developers-guides https://software.intel.com/en-us/articles/intel-graphics-developers-guides
https://software.intel.com/en-us/articles/6th-gen-graphics-api-dev-guide https://software.intel.com/en-us/articles/6th-gen-graphics-api-dev-guide
https://software.intel.com/en-us/articles/gpu-detect-sample https://software.intel.com/en-us/articles/gpu-detect-sample
https://github.com/GameTechDev/gpudetect https://github.com/GameTechDev/gpudetect
BPica
Начинающий
6 135Просмотр.
Any update about the support?
@Intel_09 do you have any info since you said that "they seem to be working on it" ?
Benjamin
PradeepNar_R_Intel
Сотрудник
6 135Просмотр.
Hi Benlehot
Please check with the game developer regarding any updates to the game. Intel graphics fully supports the game but the game developer does not include support for integrated graphics. As always, if we hear from the game developer, we will provide update.
Thank you
BPica
Начинающий
6 135Просмотр.
I sent 3 messages so far on their message board and no one is answering me
http://forums.forzamotorsport.net/turn10_postsm631128_Is-support-for-Intel-IRIS-gpu-coming.aspx Is support for Intel IRIS gpu coming? - Forza Horizon 3 Support -- PC - Forza Motorsport Forums
AFais
Начинающий
6 135Просмотр.
I think Forza Horizon 3 is playable on Intel HD Graphics. But Microsoft restrict this game to run only on other than Intel HD Graphics chip.
YES It is the matter of fact that it requires higher Graphics chip to run without shutter.
I play GTA V at 35 frame per second at low graphics.
Stefan3D
6 135Просмотр.
It's all water under the bridge now. Now we can still wait a few days for https://forzamotorsport.net/en-us/news/fm7_gamescom Forza Motorsport 7
  • Support for a Broad Range of PC SetupsForza Motorsport 7 was designed to run smoothly across a wide range of Windows 10 PCs and performance settings. Not only have we lowered our minimum specifications to i5-750, we've also reduced our recommended specifications while still having the game run at a rock solid 60 frames per second. Even gamers with a Surface Book 4 or other budget-friendly gaming PC can play the game.
Quality TargetResolutionFramerateSystem RAMIntel CPUAMD CPUNV GPUAMD GPUVRAMIntegrated GPULow720p30 fps8 GBi5-750 @ 2.67 GHzFX-6300GT 740 / GTX 650R7 250X2 GB Recommended 1080p60 fps8 GBi5-4460 @ 3.2 GHzFX-8350GTX 670 / GTX 1050 TiRX 550*4 GB Ideal (Ultra)4K60 fps16 GBi7-6700K @ 4 GHzRyzen 7GTX 1080RX Vega 648 GB Ultrabook (Mobile)720p30 fps8 GBi5-6200U or better Intel HD 520 or better
AFais
Начинающий
6 135Просмотр.
Forza Motorsports: 7 does not seems interesting as Forza Horizon: 3. But 'll try out this game. When it will out on internet?
Stefan3D
6 135Просмотр.
Demo has been released: https://www.microsoft.com/en-US/store/p/forza-motorsport-7-demo/9P2XH29364LH?rtc=1 Forza Motorsport 7 Demo - Microsoft Store
Unsurprisingly it doesn't run on ye olde Broadwell.
I tried to sneak a peek at c:\WindowsApps\Microsoft.ForzaMotorsport7Demo_1.105.697.2_x64__8wekyb3d8bbwe\media\base\targethardwareprofiler.xml, but it is unreadable even with TakeOwnershipEx
AFais
Начинающий
6 135Просмотр.
Anyone can guess how Forza Motorsports:6 Apex will run on PC with following specs
Intel core i5 having 2.40 GHz
Intel HD 520
RAM: 8GB
Ответить
