23092 Discussions
After a BIOS updating of my board DQ45CB.... please help?
I can not access to change BIOS parameters using F2.
Whwn I start the computer I use F2 but the system show me a screen with the options to load the operaring system, but I cna not access to the BIOS parameters. Is it a bug of the las bios release?
Release updated: CBQ4510H.86A.0119.EB.EXE
This does not seem to me like a BIOS bug.
First try a different keyboard (wired).
If you continue to have problems entering BIOS, go ahead and turn off the computer, change the BIOS jumper from pins 1-2 to 2-3 and turn on the computer. You will go directly in to maintenance mode in BIOS.
PV.
Thanks for your help it is all right
