22963 Discussions
After the latest update, I have started to take the errors please help
doganay258
Hello there,
Today i have updated my graphic card intel arc b580 and then after i started the spiderman 2, i started to take error that i attached below? I used to play very high and 2K and take 60 FPS.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
RandyT_Intel
Hi @doganay258
  • Please provide the SSU log report and share it here so I can review your system's configuration as mentioned by our superuser @AlHill .
  • Could you let me know the origin of the game? Where did it come from, and where did you download it?
  • Have you performed a clean installation of the graphics driver, before using the latest version?
  • Kindly share some screenshots and recordings of your game settings so we can check the issue on our end using the same settings you used.
  • Have you checked the GPU temperature? If so, what temperatures are you seeing?
  • Have you noticed any unusual noises?
  • Have you restarted the system after updating the driver?
Warm regards,
Randy T.
RandyT_Intel
Hi @doganay258
Warm regards,
Randy T.
Cap55
I am in the same boat same issue. Waiting for the fix .
DelTori
Same problem here, clean install of the last driver doesn't resolve the issue, stil get a crash each time, error DXGI from the game, temp not transmitted, and driver reset each time
RandyT_Intel
Hi @doganay258
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
@Cap55 @DelTori Please create a separate ticket for each of you so that I can have a clear understanding of the issues and provide more targeted support.
Warm regards,
Randy T.
