23854 Discussions
An Intel Driver Update Issue is Causing Further Problems on My Device.
ntnarts
Hello!
Since, I want to say, late October of last year, an issue I've had since 2022 (that had been fixed a year after) had returned, and I've spent many support calls and researching to figure out what I could do to fix this issue.
This issue I'm referring to started out as something I'd audibly notice, as every now and then, a crackle would be heard anytime I watch/listen to media on this device. As I had said before, this issue was somehow fixed in 2023 (if I remember correctly, they reinstalled some version of the BIOS, but I can't be too sure) and had not been an issue up until two years later, when it came up again after I had installed an update to the drivers of my Intel device.
My specifications are as follows:
HP-OMEN 16-k0xxx   -     Windows 11 Home Version 22H2
Processor:          12th Gen Intel(R) Core(TM) i7-12700H (2.30 GHz)
Ram:                     16 GB
Device ID:            6A55F66D-453B-421B-8D32-B78D4632CE96
Product ID:          00342-20901-81861-AAOEM
System Type:      64-bit operating system, x64-based processor
When I had given up after many attempts to getting it fixed through multiple online support assistants, I noticed that this issue had started affecting the performance and the behaviors of my PC. (Examples being distorted mic input, frame stutters when certain programs are open, when they weren't happening before.)
When I had attempted to install the recent driver version through Intel Arc, it would go through the process (using Clean Installation), and say that the drivers had been updated successfully. I'd need to restart the PC to fully finish everything, but when I do go to restart, not only would the Arc program tell me there's an update for the driver, the support website would also tell me that an error had occurred in installing the driver update.
I don't know if it's a compatibility issue, or if my device is already too outdated to get newer versions and that I have to now downgrade, I don't know. At this point, I just want answers and a way to finally fix this issue, because at the time of typing this, Intel's Live Chat system (something I've relied on that was able to fix this issue) doesn't seem to be available for me to use.
If anyone here can provide some help, advices and support for this issue I've been having, it would greatly be appreciated!
LeonWaksman
1. Did you tried to install  Intel® Graphics Driver 32.0.101.7084?
2. In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check  "Everything") and save the results. The .txt file with the results please attach to your post.
Leon
Arianfernandezz
Hola, no se me actualizan los drivers de intel.No se cual es la solucion.
# SSU Scan Information
Scan Info:
Version:"4.2.0.0"
Date:"02/03/2026"
Time:"00:00:17.5496399"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Gigabyte Technology Co., Ltd."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends International, LLC. F4 , 09/27/2024"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"12th Gen Intel(R) Core(TM) i3-12100 , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"3.6"
Sound Card:"Realtek High Definition Audio"
Sound Card:"DroidCam Virtual Audio"
Sound Card:"Camo"
System Manufacturer:"Gigabyte Technology Co., Ltd."
System Model:"H610M K V2"
System SKU:"Default string"
System Type:"x64-based PC"
- "Graphics"
Intel ® Graphics Driver Version:"32.0.101.6129"
- "Intel(R) UHD Graphics 730"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"2,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) UHD Graphics 730"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=UHD+Graphics+730"
CoInstallers:"oem52.inf,iADLSD_w10_DS,Internal,Intel(R) UHD Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"128 MB"
Driver:"igdkmdn64.sys"
Driver Date:"10/17/2024 09:00 p. m."
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_b57fc4f35ff4051b\igdkmdn64.sys"
Driver Provider:"Intel Corporation"
INF:"oem52.inf"
INF Section:"iADLSD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_b57fc4f35ff4051b\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_b57fc4f35ff4051b\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_b57fc4f35ff4051b\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_b57fc4f35ff4051b\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_4692&SUBSYS_D0001458&REV_0C\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"75 Hz"
Refresh Rate - Minimum:"50 Hz"
Resolution:"1366 X 768"
Scan Mode:"Noninterlaced"
Service Name:"igfxn"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"8076 MB"
Video Processor:"Intel(R) UHD Graphics Family"
- "Management Engine"
- "vPro"
Intel Active Management technology (AMT):"Not Detected"
- "Memory"
Physical Memory (Available):"4,85 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15,77 GB"
- "BANK 0"
Capacity:"8 GB"
Channel:"DDR5-A1"
Configured Clock Speed:"4800 MT/s"
Configured Voltage:"1100 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First position"
Manufacturer:"Kingston"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"KF556C40-8"
Serial Number:"E70A3607"
Status:"Not Available"
Type:"Synchronous"
- "BANK 0"
Capacity:"8 GB"
Channel:"DDR5-B1"
Form Factor:"DIMM"
Interleave Position:"Second position"
Serial Number:"D40A35DD"
Type:"Synchronous"
- "Motherboard"
BIOS:"F4, ALASKA - 1072009"
Caption:"Placa base"
Chipset:"Not Available"
Date:"09/27/2024 12:00 a. m."
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"H610M K V2"
Serial Number:"Default string"
Status:"OK"
Version:"x.x"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00 a. m."
Driver Path:"C:\WINDOWS\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.26100.5074"
Index:"0003"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"02/02/2026 04:50 p. m."
MAC Address:"00:E0:4C:23:99:87"
Manufacturer:"Microsoft"
Net Connection ID:"Conexión de red Bluetooth"
NetCfgInstanceId:"{C0E88BA6-4178-400B-81D5-9520029E3B90}"
PNP Device ID:"BTH\MS_BTHPAN\6&155AC7C&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Cliente para redes Microsoft:
Controlador de E/S del asignador de detección de topologías de nivel de vínculo:
Controlador de protocolo LLDP de Microsoft:
Protocolo de Internet versión 4 (TCP/IPv4):
Protocolo de Internet versión 6 (TCP/IPv6):
Respondedor de detección de topologías de nivel de vínculo:
Uso compartido de archivos e impresoras para redes Microsoft:
- "Realtek PCIe GbE Family Controller"
Caption:"Realtek PCIe GbE Family Controller"
Default IP Gateway:"192.168.0.1;fe80::4a83:c7ff:fe8c:a2ec"
DHCP Enabled:"Yes"
DHCP Lease Expires:"02/03/2026 04:33 p. m."
DHCP Lease Obtained:"02/03/2026 03:33 p. m."
DHCP Server:"192.168.0.1"
Driver:"rt640x64.sys"
Driver Date:"11/21/2023 12:00 a. m."
Driver Path:"C:\WINDOWS\system32\drivers\rt640x64.sys"
Driver Provider:"Realtek"
Driver Version:"10.69.1121.2023"
Index:"0002"
INF:"oem20.inf"
INF Section:"RTL8168H.ndi.NT"
Installed:"Yes"
IP Address:"192.168.0.11;fe80::dad:36b9:41f5:e6ea;2800:810:480:8a49:7da1:878e:700:32bc;2800:810:480:8a49:23f:56e:237d:5b9e;2800:810:480:8a49::1"
IP Subnet:"255.255.255.0;64;128;64;128"
MAC Address:"74:56:3C:FC:BB:A8"
Manufacturer:"Realtek"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{E376A49C-13DF-4422-AEDE-55EF292BC1FD}"
PNP Device ID:"PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_15\01000000684CE00000"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Realtek PCIe GbE Family Controller"
Service Name:"rt640x64"
Status:"Enabled"
Programador de paquetes QoS:
- "Settings"
*EEE:Ethernet de consumo eficiente de energía:"Activado (1)"
*FlowControl:Control de flujo:"Rx y Tx activado (3)"
*InterruptModeration:Moderación de interrupción:"Activado (1)"
*IPChecksumOffloadIPv4:Descarga de suma de comprobación IPv4:"Rx y Tx activado (3)"
*JumboPacket:Trama Jumbo:"Desactivado (1514)"
*LsoV2IPv4:Descarga de gran envío v2 (IPv4):"Activado (1)"
*LsoV2IPv6:Descarga de gran envío v2 (IPv6):"Activado (1)"
*ModernStandbyWoLMagicPacket:Wake on magic packet when system is in the S0ix power state:"Desactivado (0)"
*NumRssQueues:Número máximo de colas de RSS:"4 Colas (4)"
*PMARPOffload:Descarga ARP:"Activado (1)"
*PMNSOffload:Descarga NS:"Activado (1)"
*PriorityVLANTag:Prioridad y VLAN:"Prioridad y VLAN activada (3)"
*ReceiveBuffers:Búferes de recepción:"512 (512)"
*RSS:Escalado lateral de recepción:"Activado (1)"
*SpeedDuplex:Velocidad y Dúplex:"Negociación automática (0)"
*TCPChecksumOffloadIPv4:Descarga de suma de comprobación TCP (IPv4):"Rx y Tx activado (3)"
*TCPChecksumOffloadIPv6:Descarga de suma de comprobación TCP (IPv6):"Rx y Tx activado (3)"
*TransmitBuffers:Búferes de transmisión:"128 (128)"
*UDPChecksumOffloadIPv4:Descarga de suma de comprobación UDP (IPv4):"Rx y Tx activado (3)"
*UDPChecksumOffloadIPv6:Descarga de suma de comprobación UDP (IPv6):"Rx y Tx activado (3)"
*WakeOnMagicPacket:Reactivar en Magic Packet:"Activado (1)"
*WakeOnPattern:Reactivar en coincidencia de patrones:"Activado (1)"
AdvancedEEE:Advanced EEE:"Desactivado (0)"
AutoDisableGigabit:Desactivar Gigabit automáticamente:"Desactivado (0)"
EnableGreenEthernet:Ethernet ecológico:"Activado (1)"
GigaLite:Gigabit Lite:"Activado (1)"
PowerSavingMode:Power Saving Mode:"Activado (1)"
RegVlanid:VLAN ID:"0 (0)"
S5WakeOnLan:Activación con LAN de apagado:"Activado (1)"
WolShutdownLinkSpeed:Velocidad de enlace WOL y Apagado:"10 Mbps Primero (0)"
- "TAP-Windows Adapter V9"
Caption:"TAP-Windows Adapter V9"
DHCP Enabled:"No"
Driver:"tap0901.sys"
Driver Date:"09/27/2019 12:00 a. m."
Driver Path:"C:\WINDOWS\system32\drivers\tap0901.sys"
Driver Provider:"TAP-Windows Provider V9"
Driver Version:"9.24.2.601"
Index:"0000"
INF:"oem39.inf"
INF Section:"tap0901.ndi"
Installed:"Yes"
MAC Address:"00:FF:34:C0:1F:FA"
Manufacturer:"TAP-Windows Provider V9"
Net Connection ID:"Conexión de área local"
NetCfgInstanceId:"{34C01FFA-66E9-4301-BE24-BEB7BDBA4D5D}"
PNP Device ID:"ROOT\NET\0000"
Product Type:"TAP-Windows Adapter V9"
Service Name:"tap0901"
Status:"Enabled"
- "Settings"
AllowNonAdmin:Non-Admin Access:"Allowed (1)"
MediaStatus:Media Status:"Application Controlled (0)"
MTU:MTU:"1500 (1500)"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Google Chrome,144.0, Internet Explorer,11.1882, Microsoft Edge,144.0, OneBrowser"
Locale:"España"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Pro"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"15,50 GB"
Physical Memory (Available):"4,81 GB"
System Directory:"C:\WINDOWS\system32"
Version:"10.0.26100 Build 26100.7705"
Virtual Memory (Available):"17,28 GB"
Virtual Memory (Total):"31,27 GB"
Windows Directory:"C:\WINDOWS"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [26/12/2025]"
KB2151757:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [19/12/2025]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [26/12/2025]"
KB2467173:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [19/12/2025]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5074104:"Update [2/1/2026]"
KB5074105:"Update [2/2/2026]"
KB5074831:"Update [2/2/2026]"
KB982573:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [19/12/2025]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [26/12/2025]"
Microsoft ASP.NET Core 8.0.23 - Shared Framework (x86):".NET [16/1/2026]"
SP1:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [Not Available]"
SP1:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [Not Available]"
- "Processor"
- "12th Gen Intel(R) Core(TM) i3-12100"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 151 Stepping 5"
- "Chipset Name":"12th Gen Intel(R) Core(TM) i3-12100"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=12th+Gen++Core+i3+12100"
CPU Speed:"3,3000000000000003 GHz"
Current Voltage:"9. volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 a. m."
Driver Path:"C:\WINDOWS\system32\drivers\intelppm.sys"
Driver Version:"10.0.26100.7705"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"4 x 192 KB"
Level 2 Cache:"4 x 5120 KB"
Level 3 Cache:"12 MB"
Load:"9%"
Manufacturer:"GenuineIntel"
Model:"151"
Name:"12th Gen Intel(R) Core(TM) i3-12100"
Number of Cores:"4"
Number of Cores Enabled:"4"
Number of Logical Processors:"8"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF00090675"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"5"
- "Storage"
- "Disco virtual de Microsoft"
Capablities:"Random Access, Supports Writing"
Caption:"Disco virtual de Microsoft"
Cylinder - Total:"4"
Description:"Unidad de disco"
Error Code:"Device is working properly"
Firmware Revision:"1.0"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(Unidades de disco estándar)"
Model:"Disco virtual de Microsoft"
Partitions:"1"
PNP Device ID:"SCSI\DISK&VEN_MSFT&PROD_VIRTUAL_DISK\2&1F4ADFFE&0&000001"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"0"
SCSI LUN:"1"
SCSI Port:"1"
Sectors - Per Track:"63"
Sectors - Total:"64260"
Serial Number:"Not Available"
Size – Available:"0.0 bytes"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"1020"
- "Lexar SSD NQ100 480GB"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"Lexar SSD NQ100 480GB"
Cylinder - Total:"58369"
Firmware Revision:"SN15343"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"IDE"
Model:"Lexar SSD NQ100 480GB"
Partitions:"3"
Physical Sector Size:"512"
PNP Device ID:"SCSI\DISK&VEN_LEXAR&PROD_SSD_NQ100_480GB\4&30EC406E&0&050000"
Sectors - Total:"937697985"
Serial Number:"PKA980R0027590S303"
Size – Available:"30,47 GB"
SMART Attributes:"Self-Test: 85 minutes, OK, Short Self-Test: 2 minutes, OK"
Status:"OK"
Tracks - Total:"14884095"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Disco fijo local"
File System:"NTFS"
Name:"Not Available"
Serial Number:"689A68CA"
Size – Available:"30,477252960205078 GB"
Volume Dirty:"No"
- "SMART"
0x05 Reallocated Sector Count:0:"10"
0x09 Power-On Hours:1100:"0"
0x0C Power Cycle Count:586:"0"
0xC2 Internal Device Temperature:30° C:"0"
0xC7 CRC Error Count:0:"0"
0xF1 Total LBAs Written:12712:"0"
0xF2 Total LBAs Read:22637:"0"
...#SSU#...
LeonWaksman
Hi @Arianfernandezz
You should open a new thread of yours. You have different computer and probably other problem.
ntnarts
1. I have tried to install this exact version.
2. Here is what I have in the .txt file below.
LeonWaksman
Hi @ntnarts
1. You have BIOS set to Legacy Boot mode instead to UEFI. So, first convert it to UEFI.
2. I understand that your computer is a HP Laptop. So, after converting the BIOS Boot Mode to UEFI, find the download page for you computer in the HP site. Download the Chipset Driver and Management Engine Driver.  First, install the Chipset Driver and then The ME Driver.
3. Reboot your computer.
4. Now try to install the Intel Graphics Driver. I recommend to install the driver downloaded from the OEM site. In many cases, the OEM customizes the Graphics Driver.
Leon
ntnarts
Understood.
It'll be a bit before I can provide an update on the results on this process.
Until then, thank you so much for helping me out with this so far, hopefully this can put this laptop in the better spot it should be in.
-NTN
