23784 Discussions
A driver cannot load on device
75suited
not sure if this is the right place to post this but how do I solve the problem with windows not loading iqvw64e.sys driver?
LeonWaksman
Go to folder C:\Windows\System32\Drivers and search for iqvw64e.sys. When you find that file, right click it and select Rename, then rename that file to iqvw64e.old.
Restart your computer to apply the change.
Leon
LeonWaksman
Leon
Ramom
I would like to express my sincere gratitude for the solution provided to the problem I was facing with Windows 11. The guidance was clear, efficient, and resolved exactly the difficulty I had. It is wonderful to be able to count on such competent and attentive support. Thank you for your help!
75suited
Thank you! 🙂
