Ist es möglich mit einer intel hd 4600 2x VGA und einen DVI Monitor anzusteuern? Alle Monitore haben eine maximale Auflösung von 1366x768. Mainboard verfügt über 1x HDMI 1x DVI und 1 x VGA mit TripleMonitor-Feature (ASRock z97m)!
Is it possible to control 2x VGA and 1x DVI display (with a max display resolution of (3x) 1366x768) with the HD 4600? The mainboard has 1x HDMI 1x DVI und 1 x VGA graphics outputs and "TripleMonitor"-feature (ASRock z97m).
Hello tiefenrausch,
Let me help you with this.
When setting up three monitors using the HD 4600 it is necessary to meet some requirements or configuration.
Here you can find the information about triple monitor configuration:
http://www.intel.com/support/graphics/sb/CS-033714.htm http://www.intel.com/support/graphics/sb/CS-033714.htm
It will be necessary to have a Display Port and then you can use either VGA, DVI or HDMI but it is necessary to have the DP output as must.
Kevin m
Hello tiefenrausch,
Kevin m
Thank you for your answer!
