23525 Discussions
Any hd4600 drivers not allowing windows to load
ETorg
I've been having this issue for about a week. it started 3 weeks after purchasing a new pc with an I7 4770s processor. I'm using onboard graphics and have now tried both VGA and HDMI but get a blank screen after the windows startup logo. I've tried every driver version I can find, 2 on the intel site and 1 on the asus site for the m11ad pc. Windows loads on both hdmi and vga using the generic driver.
I've tried loading windows with the intel driver so I could connect with teamviewer but it does not come online with the intel driver installed. Therefore I think windows does not load completely unless the standard driver is installed. I'm really not sure where to go from here. My bios is up to date and I've wen from Windows 8.1 to Windows 7 with no change in status.
I will load my DXDIAG in a reply.
ETorg
System Information
Time of this report: 6/20/2014, 15:16:11
Machine name: NORMAN-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: M11AD
BIOS: BIOS Date: 08/15/13 09:08:40 Ver: 03.02
Processor: Intel(R) Core(TM) i7-4770S CPU @ 3.10GHz (8 CPUs), ~3.1GHz
Memory: 8192MB RAM
Available OS Memory: 7874MB RAM
Page File: 1637MB used, 14107MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Standard VGA Graphics Adapter
Manufacturer: (Standard display types)
Chip type: Intel(R) HSW Mobile/Desktop Graphics Chipset Accelerated VGA BIOS
DAC type: 8 bit
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_85341043&REV_06
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1024 x 768 (32 bit) (1Hz)
Monitor Name: LG E2341(HDMI)
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: vga
Driver File Version: 6.01.7600.16385 (English)
Driver Version: 6.1.7600.16385
DDI Version: unknown
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: 7/13/2009 16:38:47, 15360 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-F233-84B8A8C2CB35}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0x85341043
Revision ID: 0x0006
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
Sound Devices
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_104385C2&REV_1003
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7601.17514 (English)
WHQL Logo'd: Yes
Date and Size: 11/20/2010 20:23:47, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC517
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
V...
Kevin_M_Intel
Hi AlphaChill,
I am sorry to hear you are having this problem but let me help you with this.
Based on your description, there are some troubleshooting steps I want you to try. I see you have tested VGA and HDMI so I wonder, have you tried DVI? Is there a chance to test this connection?
It is also important t say that it is very important and necessary to use a direct connection (no video adapters) to avoid interference with the signal.
Besides these steps, you can try updating the BIOS to latest from your Computer Manufacture.
ETorg
Thank you for your reply, Kevin. DVI is not an option on this motherboard. I am using direct connections for both hdmi and vga. I can try updating the bios the next time I am over there and see if there's any difference.
Kevin_M_Intel
Oh Right, just let me know!
Kevin M
