22661 Discussions
Arc 750 limited edition graphic card problem
Surajit007
Maya GPU Rendaring error
Andres_Intel
Hello Surajit007,
Thank you for posting on the Intel®️ communities. I will be more than happy to help you. Since you are having rendering issues in Maya with your Intel® Arc™ A750 Graphics. In order to enhance comprehension of the circumstances, kindly respond to the following inquiries:
Andres P.
Surajit007
Surajit007
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"01-05-2024"
Time:"00:00:26.3119861"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Gigabyte Technology Co., Ltd."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends International, LLC. FC , 03/25/2022"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"3.3"
Sound Card:"Realtek High Definition Audio"
System Manufacturer:"Gigabyte Technology Co., Ltd."
System Model:"H510M H"
System SKU:"Default string"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Arc(TM) A750 Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Arc(TM) A750 Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Arc+A750+Graphics"
CoInstallers:"oem13.inf,iDG2_Client_FWU_w10_DS,Internal,Intel(R) Arc(TM) A750 Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdnd64.sys"
Driver Date:"12-21-2023 05:30 AM"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igdkmdnd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"31.0.101.5084"
INF:"oem13.inf"
INF Section:"iDG2_Client_FWU_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_31f0afbf31adacfe\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_56A1&SUBSYS_10218086&REV_08\6&291E387B&0&00080008"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"100 Hz"
Refresh Rate - Minimum:"50 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"igfxnd"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Arc(TM) A750 Graphics Family"
- "Memory"
Physical Memory (Available):"10.55 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15.87 GB"
- "BANK 0"
Capacity:"8 GB"
Channel:"Controller0-ChannelA"
Configured Clock Speed:"2666 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First position"
Manufacturer:"A-DATA Technology"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"DDR4 3200"
Serial Number:"254D0000"
Status:"Not Available"
Type:"Synchronous"
- "BANK 1"
Capacity:"8 GB"
Channel:"Controller0-ChannelB"
Form Factor:"DIMM"
Interleave Position:"Second position"
Serial Number:"464E0000"
Type:"Synchronous"
- "Motherboard"
BIOS:"FC, ALASKA - 1072009"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"03-25-2022 05:30 AM"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"H510M H"
Serial Number:"Default string"
Status:"OK"
Version:"x.x"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Realtek PCIe GbE Family Controller"
Caption:"Realtek PCIe GbE Family Controller"
CoInstallers:"Not Available"
Default IP Gateway:"10.11.207.129"
DHCP Enabled:"No"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"rtcx21x64.sys"
Driver Date:"01-02-2021 12:00 AM"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\rtcx21x64.inf_amd64_516e5c9b75c49dc2\rtcx21x64.sys"
Driver Provider:"Microsoft"
Driver Version:"1.0.0.14"
Index:"0001"
INF:"rtcx21x64.inf"
INF Section:"RTL8168H.ndi.NT"
Installed:"Yes"
IP Address:"10.11.207.203"
IP Subnet:"255.255.255.128"
Last Reset:"01-05-2024 05:37 PM"
MAC Address:"74:56:3C:30:76:5D"
Manufacturer:"Realtek"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{C387E672-04A2-485C-9B0E-3A347179F998}"
PNP Device ID:"PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_15\01000000684CE00000"
Port:"Not Available"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Power Management Supported:"No"
Product Type:"Realtek PCIe GbE Family Controller"
Service Name:"rtcx21"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
QoS Packet Scheduler:
- "Settings"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*InterruptModeration:Interrupt Moderation:"Enabled (1)"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
*JumboPacket:Jumbo Frame:"Disabled (1514)"
*LsoV2IPv4:Large Send Offload v2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload v2 (IPv6):"Enabled (1)"
*PMARPOffload:ARP Offload:"Enabled (1)"
*PMNSOffload:NS Offload:"Enabled (1)"
*PriorityVlanTag:Priority & VLAN:"Priority & VLAN Enabled (3)"
*ReceiveBuffers:Receive Buffers:"512 (512)"
*RscIPv4:Recv Segment Coalescing (IPv4):"Disabled (0)"
*RscIPv6:Recv Segment Coalescing (IPv6):"Disabled (0)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*TransmitBuffers:Transmit Buffers:"128 (128)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on pattern match:"Enabled (1)"
RegVlanid:VLAN ID:"0 (0)"
S5WakeOnLan:Shutdown Wake-On-Lan:"Enabled (1)"
WolShutdownLinkSpeed:WOL & Shutdown Link Speed:"10 Mbps First (0)"
- "Operating System"
.Net Framework Version:"4.0,4.8"
Boot Device:"\Device\HarddiskVolume4"
Internet Browser:"Google Chrome,120.0, Internet Explorer,11.1, Microsoft Edge,120.0"
Locale:"United States"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Pro"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"2.38 GB"
Physical Memory (Available):"10.57 GB"
System Directory:"C:\WINDOWS\system32"
Version:"10.0.22631 Build 22631"
Virtual Memory (Available):"10.18 GB"
Virtual Memory (Total):"18.25 GB"
Windows Directory:"C:\WINDOWS"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [15-12-2023]"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [15-12-2023]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [15-12-2023]"
KB2467173:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [15-12-2023]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB5027397:"Update [10/1/2023]"
KB5032007:"Update [12/13/2023]"
KB5032393:"Update [12/13/2023]"
KB5033055:"Update [12/13/2023]"
KB5033375:"Security Update [12/13/2023]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [15-12-2023]"
KB982573:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [15-12-2023]"
Microsoft ASP.NET Core 7.0.7 - Shared Framework (x64):".NET [13-12-2023]"
- "Processor"
- "Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 165 Stepping 3"
- "Chipset Name":"Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core+i5+10400F+CPU+"
CPU Speed:"2.90 GHz"
Current Voltage:"8. volts"
Driver:"Not Available"
Driver Date:"04-21-2009 12:00 AM"
Driver Path:"C:\WINDOWS\system32\drivers\intelppm.sys"
Driver Version:"10.0.22621.2506"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"6 x 384 KB"
Level 2 Cache:"6 x 1536 KB"
Level 3 Cache:"12 MB"
Load:"0%"
Manufacturer:"GenuineIntel"
Model:"165"
Name:"Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz"
Number of Cores:"6"
Number of Cores Enabled:"6"
Number of Logical Processors:"12"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF000A0653"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"3"
- "Storage"
- "CT500BX500SSD1"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"CT500BX500SSD1"
Cylinder - Total:"60801"
Description:"Disk drive"
Driver Date:"06-21-2006 12:00 AM"
Error Code:"Device is working properly"
Firmware Revision:"M6CR061"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Interface Type:"IDE"
Manufacturer:"(Standard disk drives)"
Model:"CT500BX500SSD1"
Partitions:"3"
Physical Sector Size:"512"
PNP Device ID:"SCSI\DISK&VEN_&PROD_CT500BX500SSD1\4&5D48514&0&030000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
Sectors - Per Track:"63"
Sectors - Total:"976768065"
Serial Number:"2320E6D72FE3"
Size – Available:"223.40 GB"
SMART Attributes:"Self-Test: 10 minutes, OK, Short Self-Test: 2 minutes, OK"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"15504255"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Local Fixed Disk"
File System:"NTFS"
Name:"Not Available"
Serial Number:"F89975DB"
Volume Dirty:"No"
- "SMART"
0x01 Raw Read Error Rate:0:"51"
0x05 Reallocated Sector Count:0:"140"
0x09 Power-On Hours:485:"0"
0x0C Power Cycle Count:367:"0"
0xAB Program Fail Count:0:"0"
0xAC Erase Fail Count:0:"0"
0xAD Wear Leveling Count:18:"0"
0xAE Power-off Retract Count:28:"0"
0xB4 Unused Reserved Block Count Total:41:"0"
0xB7 SATA Downshift Count:0:"0"
0xB8 End-to-End Error Detection Count:0:"97"
0xBB Uncorrectable Error Count:0:"0"
0xC2 Internal Device Temperature:28° C:"0"
0xC4 Reallocation Count:0:"0"
0xC5 Current Pending Errors Count:0:"0"
0xC6 Uncorrectable Sector Count:0:"0"
0xC7 CRC Error Count:0:"0"
0xCA Data Address Mark Errors:2:"0"
0xCE Flying Height:0:"0"
0xD2 Vibration During Write:0:"0"
0xF9 Total NAND Writes:0:"0"
0xFB Minimum Spares Remaining:3304825052:"0"
0xFC Newly Added Bad Flash Block:1:"0"
- "WD7500A"
Caption:"WD7500A"
Cylinder - Total:"91201"
Firmware Revision:"01.01R.3"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Model:"WD7500A"
Partitions:"2"
PNP Device ID:"SCSI\DISK&VEN_&PROD_WD7500A\4&5D48514&0&010000"
Sectors - Total:"1465144065"
Serial Number:"WDC-ROM SN# XYZ----"
Size – Available:"552.61 GB"
SMART Attributes:"Self-Test: 139 minutes, OK, Short Self-Test: 2 minutes, OK"
Status:"OK"
Tracks - Total:"23256255"
- "E:"
Caption:"E:"
File System:"NTFS"
Serial Number:"7CB6F6E2"
Size – Available:"311.91 GB"
Volume Dirty:"No"
- "F:"
Caption:"F:"
File System:"NTFS"
Serial Number:"C8BAACE8"
Size – Available:"240.70 GB"
Volume Dirty:"No"
- "SMART"
0x03 Spin Up Time:1891:"21"
0x04 Start/Stop Count:1141:"0"
0x07 Seek Error Rate:0:"0"
0x09 Power-On Hours:921:"0"
0x0A Spin Retry Count:0:"0"
0x0B Calibration Retry Count:0:"0"
0x0C Power Cycle Count:538:"0"
0xBC Reported Command Timeouts:0:"0"
0xBE Temperature - Current:25° C:"0"
0xBE Temperature - Highest:Not Available:"0"
0xBE Temperature - Lowest:Not Available:"0"
0xC0 Unsafe Shutdown Count:23:"0"
0xC1 Load/Unload Cycle Count:6175:"0"
0xC2 Internal Device Temperature:25° C:"0"
0xC3 Hardware ECC Recovered:0:"0"
0xC8 Write Error Rate:0:"0"
0xF0 Head Flying Hours:638:"0"
0xF1 Total LBAs Written:2273455521:"0"
0xF2 Total LBAs Read:2561592165:"0"
...#SSU#...
Andres_Intel
Hello Surajit007,
Thank you for your response and for sharing all the information.
I see you have checked the Intel® SSU and I see that there are some pending updates, please follow the steps below and let me know the results:
Andres P.
Surajit007
my current driver is 31.0.101.5084
found the way
Andres_Intel
Hello Surajit007,
Thank you for your response.
Please answer the questions below for clarification:
  • Were you able to use the DDU and then install the driver 31.0.101.5084? Using the DDU before installing the driver may change the behavior of the graphics card.
  • Were you able to update BIOS to version FE?
Keep me informed of the results.
Andres P.
Surajit007
Gigabyte H510M H motherboard FE BIOS not available F2 bios update Available
Andres_Intel
Hello Surajit007,
Thank you for letting me know the results.
I was able to find the BIOS version FE in the Gigabyte website, remember this is really important for the stability of the graphics card. In case, you are having issues with the installation you can contact them.
Let me know the results.
Andres P.
Surajit007
bios update
graphic driver DDU
evrithing done
but problem still available
Andres_Intel
Hello Surajit007,
Thank you for your answer and for completing the steps.
I will start with an investigation to provide you with the next steps as soon as possible.
Andres P.
Andres_Intel
Hello Surajit007,
Thank you for your time.
We have been working on the investigation, and now we would like to replicate the issue, can you provide us with a video showing the step-by-step instructions for us to try to reproduce it as accurately as possible?
Andres P.
Surajit007
i can not post video
Andres_Intel
Hello Surajit007,
Thank you for your reply and for the screenshot.
The screenshot will help for the replication, but for me is not clear enough how to open the Render Settings Window, in this case since you are not able to post the video directly to the thread you can upload it to a cloud like Google Drive, OneDrive, etc, and post the link to the thread. Make sure to give us the authorization to watch it.
If you create a project file and we need it for the replication, it also will be useful is you provide us with the file.
Thank you for your help. Once we have this information I will me more than glad to start with the replication.
Andres P.
Surajit007
Andres_Intel
Hello Surajit007,
Thank you for providing us the video.
Now I will start with the replication of the issue and as soon as I have the I will let you know.
Andres P.
Surajit007
found something intel
Andres_Intel
Hello Surajit007,
We are still working on the replication, we hope to have the results soon, once I have them I will let you know.
Andres P.
Andres_Intel
Hello Surajit007,
We have been working on the replication, we hope to have the results soon, as soon as I have them I will let you know.
Andres P.
Andres_Intel
Hello Surajit007,
Thank you for all your time.
We have been working on the replication, and I want to let you know that this is expected behavior, as Arnold Renderer is not supported on Intel Arc graphics cards. Nvidia/CUDA is the only supported option currently.
Let me know if you have further questions.
Andres P.
Surajit007
There is no way, I can't afford to buy an nvidia card, I bought the computer with 5 years of savings, I shouldn't have trusted Intel, you should have seen what software supports the card while making it, I wish you well, I wish you good health, next time these mistakes Don't do it, many people's dreams can be ruined, people trust you
good bye take care
