23553 Discussions
Arc A380
LCR1
Can the Arc A380 support 4 monitor outputs at once
I want to run 4 x 1080p@60Hz off 1 A380 GPU.
If it can, then can I run 8 separate monitors off 2 A380's in one PC?
Hugo_Intel
Hello LCR1
Thank you for posting on the Intel Communities.
The Intel® Arc™ A380 GPU can certainly support up to 4 displays connected to its video ports so you should not have an issue using this configuration, check the GPU specification on this link. As for if you can use 8 monitors by using 2 GPUs, this is an uncommon confirmation and I would need to check if there is any information available, so allow me to check this with our team and I will let you know since I have an update.
Hugo O.
LCR1
Hugo_Intel
Hello LCR1
Upon checking your questions with our team we can confirm that an 8-display configuration can be configured using 2 A380 GPUs with no problem, the OS will configure and drive the displays, there are no extra settings that need to be adjusted for it to work.
Hugo O.
Hugo_Intel
Hello LCR1
As mentioned in our previous post, an 8-monitor configuration can be used when using 2 A380 GPUs. We hope the information we provided was useful to you, since there are no further questions we will be closing this thread. If you need further assistance feel free to open a new topic.
Hugo O.
