23466 Discussions
Arc A770 - Losing video output
boazvdw
My ARC A770 sometimes loses video output when changing to fullscreen. For example while I'm playing a game (rocket league in my instance, but did notice it on other games too) and press alt+tab to switch out of rocket league's fullscreen window and then try to alt+tab back in to rocket league my video output will be lost.
I heard this might be caused by using HDMI to my monitor instead of displayport cables. Unfortunetly I don't have any displayports available since I'm using a TV.
My setup:
Mobo: Asus Hero VIII
GPU: Arc A770
CPU: Ryzen 5600X
RAM: 32GB 3200MHz
Re-Bar: Enabled
PC HDMI OUT -> TV HDMI IN
Hugo_Intel
Hello boazvdw
Thank you for posting on the Intel Communities. I am sorry to hear that you are experiencing issues when changing fullscreen mode with your Intel® Arc™ A770 Graphic. We would like to gather the following information to assist you with this issue:
  • What is your TV make and model?
  • Is pressing the alt+tab buttons when playing a game the only way to trigger this issue or does it happen to you in different scenarios?
  • Have you tried different HDMI cables?
  • Are you using any type of video adapters or dongles?
  • Create a log file with the Intel® System Support Utility and attach it.
Hugo O.
boazvdw
Hi Hugo,
Apologies for my late reply. My TV is a Samsung UE50RU7172U (4k 60hz). The issue is mostly happening when alt+tabbing but might also happen after a reboot (most of the time when it happens after reboot it'll take a minute or something until it starts to display output, unless I take out the HDMI and replug it). I have also tried different cables already but without success unfortunatly. Please reach out to me if more information is needed.
Kind regards,
Boaz
Hugo_Intel
Hello boazvdw
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello boazvdw
Thank you for sharing this information with us. Please let's try the following:
  • Go to your motherboard manufacturer's website and update your Bios to the latest version. The latest version should be 4402.
  • Make sure that your TV's firmware is updated to the latest version. You can check the latest firmware available on the manufacturer's website.
  • Reseat the GPU on its PCIE slot.
  • If possible, please try a different monitor.
If the issue continues, please share with us the following information:
  • Attach a short video showing the issue
  • Create a System report following these instructions. Only use the instructions under Intel Graphics Command Center (Intel GCC).
Hugo O.
Hugo_Intel
Hello boazvdw
Please let us know if the advised troubleshooting helped with this issue or, please provide us with the information requested to further assist you.
Hugo O.
Andres_Intel
Hello boazvdw,
Andres P.
