23851 Discussions
Failed to install Intel Driver Update Utility software
tahsincupcake
I have tried to install Driver Update Utility software in my PC but failed several times. I need this software to install Intel HD Graphics driver. At first it got stuck on the Initializing phase. Tried repairing several times. But it says failed with a log file. I have attached the log file here. If anybody could help me to install Intel HD Graphics driver.
AlHill
You do not need IDSA to install the graphics driver.
What is your processor model number?
tahsincupcake
My processor model number is Intel® Core™ i3-9100 CPU @ 3.60GHz
AlHill
This is your processor:
https://ark.intel.com/content/www/us/en/ark/products/134870/intel-core-i39100-processor-6m-cache-up-to-4-20-ghz.html
On the left, look at drivers and software.
Specifically, your graphics driver can be found here when you follow the links:
https://www.intel.com/content/www/us/en/download/762755/intel-6th-10th-gen-processor-graphics-windows.html
tahsincupcake
I have already tried this driver several times. It says "Something went wrong. No driver was found that can be installed on the current device. Installer exit code: 8." along with a Error log. I have attached the error log and the screenshot of the driver installer.
AlHill
Do you have a graphics card installed, like nvidia or amd?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
tahsincupcake
I want to install intel integrated graphics driver into my PC.
