23837 Discussions
Arc control bugged out
MichelN86
Since the last update for intel Arc 4577 and 4578 beta the arc control does not startup anymore at boot. I reinstalled it 4th times, tried different methods (driver delete, arc control delete / overwrite older driver with the newer one) and nothing works.
At startup you see the services loaded but the panel does not work at all, when i select open arc control nothing happend and when i select quite arc control nothing happens either. When i disable the services and then open arc control it does work and respond as it should. When i reboot the same thing happen again. Please fix your drivers! I had none issues with previouse releases.
Link to my video:
Log posted below.
MichelN86
I fixed my own issue, thanks intel for the help or a reply! Disable the Arc services in systemconfig and reboot did fix my issue.
This is from a fresh boot after closing the services, so your Arc services is the main issue here.
MichelN86
Jose_Intel
Hello @MichelN86
Thank you for posting on the Intel️® communities.
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing a similar behavior.
Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel.
Jose B.
MichelN86
Maybe try to fix the issue in your newer driver updates. Someone else also confirmed it is related to the Arc Services
https://forum-en.msi.com/index.php?threads/msi-crosshair-15-b12u-latest-driver-updates.387144/page-3#post-2205348
Scroll down and you will see it.
As for the ssu log, you see the same thing. “Cannot start the service because it is disabled”
Servicebesturingsbeheer heeft na het onverwachte afsluiten van de Intel(R) Arc Control Service-service geprobeerd een herstelactie (Restart the service) uit te voeren, maar deze actie is met de volgende fout mislukt:
Kan de service niet starten omdat deze is uitgeschakeld of omdat het geen ingeschakelde apparaten met zich heeft verbonden.
