22648 Discussions
Are Dual monitors possible with MOBILE INTEL HD GRAPHICS 4400?
RKenl
Can i use two external monitors with the mobile intel HD graphics 4400 that is on my Core I-3 4005 processor?Toshiba only installed an HDMI and not a VGA. Could I go through the USB with a USB to HDMI converter to create a second HDMI?
Cesar_B_Intel
Hello @ rkenley2
The Intel® HD Graphics 4400 supports dual display. However, Intel® recommends straight connections using a high quality HDMI* cable. The use of adapters , dual display cables , KVM's may work, however you may experience display issues.
If your device does not have another type of video output it means its hardware was designed to support one additional display.
RKenl
Thanks for the help Cesar. Sounds like i can try a $15 adapter and if it works I'm lucky, but keep the receipt for the adapter.
