23526 Discussions
Arma 3 dxgi_error_device_removed
JMali1
Hello
I am receiving this error when playing arma 3 atlis life. I've read through several forums and the only solution I have been able to find is downgrading the driver to 9.17.10.2932 ( source ) which I am unable to do. Whenever I try to downgrade I receive a message stating my computer does not meet the minimum requirements. I spent a couple hours chatting with asus support and they were less then helpful.Can anyone help?
Asus R500A
Windows 8.1
Intel HD 4000
Current driver is 10.18.10.3308
Kevin_M_Intel
Hello underdone,
Thanks for posting your question here.
Please note this question has been done in a different thread. You can refer and continue working there since it is for the same issue:
/thread/53258 https://communities.intel.com/thread/53258
Kevin M
JMali1
Hello Kevin
Thank you for your response, I am aware that I need to downgrade however as I mentioned in my OP I am unable to do so because I get i get an error message stating my computer doesnt meet the minimum requirements. Is there a work around to get my computer to accept 2932?
Kevin_M_Intel
Sure. Try the steps mentioned at this link:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
