23101 Discussions
Artifacts/Flickering on my Laptop Screen after Latest DCH Driver update
HMazo
Hello Everyone. I have been experiencing these weird artifacts on my screen after updating my graphics drivers to the latest DCH drivers. I recently installed the Windows 10 Insider Preview
AlHill
Use only the driver supplied by your laptop manufacturer, and use the released version of W10 (1903). If the artifacts are gone, problem solved.
If not, you are a beta tester and need to report the problem to Microsoft.
Doc
HMazo
Thank you. I'm a beta tester. I will do so shortly.
HMazo
Update: I installed an older version of Windows (May 2019 Update) but the problem still persists. In the Device Manager, in the driver events it displays the following message: igfx has not started. Somehow I think this is linked to the problem. It's the screenshot I have attached.
AlHill
Use only the driver(s) provided by your laptop manufacturer with the 1903 version of W10. Do not use the generic Intel drivers.
If the problem is still there, contact your laptop manufacturer for support, as they are solely responsible for support of your laptop.
Also provide your processor model number.
Doc
HMazo
Model Number: i5-8250U CPU
I used the event viewer to see what the event was that was listed on the Device Manager:
Log Name:     Microsoft-Windows-Kernel-PnP/Configuration
Source:       Microsoft-Windows-Kernel-PnP
Date:         2019/08/10 16:19:01
Event ID:     411
Task Category: None
Level:        Error
Keywords:
User:         SYSTEM
Computer:     DESKTOP-ILRBA1R
Description:
Device PCI\VEN_8086&DEV_5917&SUBSYS_8377103C&REV_07\3&11583659&0&10 had a problem starting.
Driver Name: oem3.inf
Class Guid: {4d36e968-e325-11ce-bfc1-08002be10318}
Service: igfx
Lower Filters:
Upper Filters:
Problem: 0x15
Problem Status: 0x0
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
 <System>
   <Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" />
   <EventID>411</EventID>
   <Version>0</Version>
   <Level>2</Level>
   <Task>0</Task>
   <Opcode>0</Opcode>
   <Keywords>0x4000000000000000</Keywords>
   <TimeCreated SystemTime="2019-08-10T14:19:01.832283800Z" />
   <EventRecordID>366</EventRecordID>
   <Correlation />
   <Execution ProcessID="4" ThreadID="32" />
   <Channel>Microsoft-Windows-Kernel-PnP/Configuration</Channel>
   <Computer>DESKTOP-ILRBA1R</Computer>
   <Security UserID="S-1-5-18" />
 </System>
 <EventData>
   <Data Name="DeviceInstanceId">PCI\VEN_8086&amp;DEV_5917&amp;SUBSYS_8377103C&amp;REV_07\3&amp;11583659&amp;0&amp;10</Data>
   <Data Name="DriverName">oem3.inf</Data>
   <Data Name="ClassGuid">{4D36E968-E325-11CE-BFC1-08002BE10318}</Data>
   <Data Name="ServiceName">igfx</Data>
   <Data Name="LowerFilters">
   </Data>
   <Data Name="UpperFilters">
   </Data>
   <Data Name="Problem">0x15</Data>
   <Data Name="Status">0x0</Data>
 </EventData>
</Event>
AlHill
Good. Now, contact your laptop manufacturer for support.
Doc
