23784 Discussions
Atom Z3735 Windows 10
JRiši
When wil be corect drivers for tablets Atom w10 z3735g
Nothing works when reinstal w10 no tachsreen, batery, sound, gpu ,...
Windows update atleast something intall but not platform driver i haw to use w8.1 and then may be incorect, device manager
Intel
Stefan3D
According to https://ark.intel.com/products/80275/Intel-Atom-Processor-Z3735G-2M-Cache-up-to-1_83-GHz Intel Atom® Processor Z3735G (2M Cache, up to 1.83 GHz) Product Specifications you have a Baytrail 3rd Gen GPU.
Use this driver
If you encounter an error message about validation install the driver via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
When you say "platform driver" do you mean Intel chipset driver? If so try this one:
https://downloadmirror.intel.com/26655/eng/Chipset_Win7_8.1_10_10.1.1.8.zip https://downloadmirror.intel.com/26655/eng/Chipset_Win7_8.1_10_10.1.1.8.zip
Afaik touchscreen and battery drivers are not made by Intel, you need to contact the manufacturers.
In worst case touchscreen requires a firmware update.
Stefan3D
Use this driver
JRiši
That graphics driver makes error and wont continue a can only instal win8.1 Intel platform installer week 28.5 0x00A firs and then Windows update. In Device manager i can istal newer ones manualy but some off them is not corect event viwer makes lot off errors.
JRiši
Windows 10 do not haw i2c controller, after one manual install in device m. from platform drivers only then it find others, except cameras for my tablet.
Hello janis2017,
Please bear in mind that this is an OEM (Original Equipment Manufacturer) system and your best contact support is with your computer manufacturer as they are more familiar with your system and how all the components interact with each other.
Your Tablet came with a specific operating system and it depends on your computer manufacturer if Windows® 10 will work or not. Also, any driver for this processor is provided by your computer manufacturer.
Ivan U.
JRiši
Windows 8.1 Bing is not downloadable!!!
