23070 Discussions
Audio and video too fast on HD4200 (4030Y) when on HDMI
ESimó
Dear all,
I recently bough a mini PC with a Haswell 4030Y that has HD4200 graphics and Intel Display Audio. If I connect to a TV via HDMI, all videos and music run too fast.
I have reinstalled drivers (Win 10 Pro) but it did not solve the problem. Tried in another TV via HDMI and problem persists. Audio and video are fine when using headphones via jack or bluetooth.
Any idea will be welcome!
Hi esimon,
I would need to know more details of your system before giving to you a recommendation. Let me know which program you are using to run the videos and music; also please send to me the results of our tool Intel® System Support Utility.
Let me know how Youtube videos work.
SSU
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600 https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600
Mike C
ESimó
Hi Mike,
Thanks for responding.
The issue with the high pitch happens with all programs I have tried (MS Edge, Groove music, Firefox, internet radio,...) and only when connected via HDMI. Funny enough, the youtube videos also run fast but, if I switch to the bluetooth headphones, they start playing at the normal speed.
I-m pasting below the result of the SSU scan /sorry, I didn't find out how to upload the xml file.
Please let me know if you need any more info and thanks again for the support.
Operating System: Microsoft Windows 10 Pro(10.0.10586 Build 10586)
Physical Memory (Installed): 2 GB
Processor : Intel(R) Core(TM) i3-4030Y CPU @ 1.60GHz
System Type: x64-based PC
Display Adapter(s): Intel(R) HD Graphics Family 20.19.15.4463
System Manufacturer: INTEL Corporation
System Model: CRESCENTBAY
Network Adapter(s): Bluetooth Device (Personal Area Network) 10.0.10586.0
Qualcomm Atheros QCA9565 802.11b|g|n WiFi Adapter 10.0.0.318
Realtek PCIe GBE Family Controller 9.1.402.2015
Disk(s): General USB Flash Disk USB Device 29.80 GB (available) 10.0.10586.0
SSD64GB 40.46 GB (available) 10.0.10586.0
Hi esimon,
I need to collect more details of your system before giving a proper troubleshooting. Run again our tool Intel® System Support Utility and attach the results using the steps below:
-Click on reply
-Click Use advanced editor (upper right side)
-Click Attach (lower right hand)
Mike C
ESimó
Here goes the SSU report.
Hi esimon,
Thank you for your answer. I verify your system configuration and everything looks good. I noted you are using the latest generic graphics driver 4463.
I suggest you to visit your laptop manufacturer and verify if you are using the latest BIOS, chipset and graphics driver. Pre-build systems use customized drivers, usually Intel drivers do not work.
Mike C
Hi esimon,
I am following your case. Are you still having issues with the video?
Mike C
