23457 Discussions
Audio resolution problem with HD530 and i5 6600K
fchap1
This deals with Intel Display Audio Driver. If it is in the wrong place, please advise.
I built a HTPC with a Gigabyte Z170X-Gaming 7 motherboard with HD530 and an Intel Skylake i5 6600K cpu. 64-bit. The motherboard complies with HDMI 2.0 and HDCP 2.2.
I downloaded and installed the newest Intel HD Graphics driver version 15.40.7.4279 (Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows® 7, 8.1, & 10)
In Advanced Properties under my DENON-HDAVR playback sound device, the '24-bit, 192000 Hz (Studio Quality)' default format did not show up in Windows 8.1, 64-bit Pro. But it does show up in Windows 7 64-bit Pro.
The Intel HD Graphics zip file contains two folders under the 'DisplayAudio' folder. One is entitled "6.16" and the other is "8.20". The 8.20 version is automatically chosen and installed (the Intel Display Audio properties states version 8.20.0.541). I just discovered that when I force the "6.16" .inf file to install, the missing resolution is listed. While installing the 6.16 version, an "Update Driver Warning" is displayed stating the driver is not recommended.
I have switched back and forth between the two versions and 8.20 never displays the 24-bit, 192000 Hz resolution and the 6.16 version always does.
Does this indicate a problem with the Intel driver selection process for this motherboard?
As information, I initially installed the drivers that came with the motherboard. I later updated those drivers with the drivers on the Gigabyte site. The aforementioned resolution was missing in both cases within Windows 8.1.
Thank you.
Allan_J_Intel1
I need you to fill out the following form:
I will try to replicate this issue and update this thread as soon as possible.
Allan.
fchap1
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
The 24 bit, 192000 Hz audio resolution is not listed under my AVR HDMI device in Windows 8.1 when the newest audio driver version 8.20.2.541 is used. However that resolution does show up when I use audio driver version 6.16.0.3180, which seems to be the proper driver for Windows 7. But I have to force install ver. 6.16.0.3180 and ignore a warning against its installation.
I believe the same issue exists with Windows 10 as it does with Windows 8.1. But I didn't pursue the issue with Windows 10 sufficiently. However I could pursue the Windows 10 issue if requested to do so.
When using 64-bit Windows 7 Pro on this same PC, the default HD Audio driver installed is the 6.16.0.3180 and the 24-bit, 192000 audio resolution is present.
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
Every single time. I can switch between drivers and the problem always occurs with version 8.20.2.541.
Hardware (HW)
Brand and Model of the system.
Gigabyte z170x-gaming 7 (rev. 1) motherboard. Skylake i5 6600K processor, 8 GB DDR4 RAM
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No. Using integrated HD530 graphics.
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP</st...
fchap1
Thank you Allan. Please advise if I haven't provided all the information you require.
Thanks for the help!
Frank Chapman
Allan_J_Intel1
Thanks for the information. I have escalated this matter to our engineering team. If I need anything else, I will update this thread.
Allan.
fchap1
Thank you Allan,
I just tried two newer drivers. So if the engineering team wonders whether Intel's most recent drivers work, here are the results:
driver 8.20.0.580 had the same problem as 8.20.0.541 mentioned above and is the recommended driver for Windows 8.1 and 10
driver 6.16.0.3182 works in Windows 8.1 just as 6.16.0.3180 did, but is most likely for Windows 7. And it has to be forced to install in Windows 8.1
Allan_J_Intel1
Allan.
DCalv2
Hello Allan,
I can confirm the problem still exists (and it seems to be quite common according to some A/V forums)
My machine is a sixth gen. i7 (see details below). Summing up the issue:
  • With audio driver version 8.20.00.745:
    • No 24/192 audio output possible through HDMI, neither using DirectSound nor WASAPI
    • Máximum output seems to be 176 kHz (not sure if 16 bit or 24 bit)
  • With audio driver version 6.16.00.3190:
    • 24/192 audio output is OK
Thanks for checking this issue again
Category
Questions
Description
Failure to output audio at 24 bit / 192 kHz
Everytime
Hardware (HW)
HP 15" Pavillion ak-003 laptop (i7-6700HQ at 2.6 GHz)
Switchable: Intel HD Graphics 530 & Nvidia GeForce 950M GTX. The issue appears no matter the card working.
EFP = External Flat Panel (Monitor you plug in)
Marantz SR6006 A/V receiver & Samsung UE55D6530 digital TV
How much memory [RAM] in the system (see note2 below).
16 GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
HDMI 1.4 certified wires
Hardware Stepping (see note1 below)...
Allan_J_Intel1
Would you try the following driver?
https://downloadcenter.intel.com/download/25848/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows* 7/8.1/10 [15.40]
Please let me know your findings.
Allan.
I confirm that this problem continues with Intel HD 530 on Intel i5-6600K and i7-6700HQ
The new driver
Intel® Graphics Driver [15.45]
Version: 15.45.10.4542 (Latest) Date: 11/9/2016
and old driver
Intel® Graphics Driver for Windows® 7/8.1/10* [15.40 6th Gen]
Version: 15.40.14.4352 (Latest) Date: 12/23/2015
They have the same problem
The new version of (Intel screen sound 10.2.0.0.96) does not solve the problem
It has been more than a year that intel is aware of this problem and continues without repair its drivers
This problem is located on Windows 10 x64 and Windows 8.1 x64
The sound can not be heard at more than 48,000 Khz at 16 or 24 bits on my ONKYO TX-NR747 Full firmware update (08-31-2016), and using HDMI 2.0a cables high quality.
In windows 7 x64 it works correctly with the driver version 6.16.00.3190 but this version of the driver is not able to work in windows 10 x64 correctly
If this community forum can not report this problem to Intel support, I ask that I be given an address or link, where I can inform the Intel technical support department to open an issue, if they are so kind.
Thank you very much.
