22940 Discussions
Audio through HDMI and Monitor sleep
MNemi
Hello.
I am using my digital receiver Onkyo TX-SR309 to play audio from ASUS P8Z68-V PRO/GEN3 with Core i7 3770K connected with HDMI-HDMI cable.
Here is situation: I am listening radio and don't use OS, so after the idle time in Power managent of user inactivity, OS send in sleep monitor and sound at receiver disappear.
I found only one driver 15.31.18.3272 from ASRock (Graphics 9.18.10.3272 and 6.16.0.3112 audio) that don't stop playing after system enters monitor in sleep after idle.
I try some next and new 15.33.9.3355 but always get lost of sound from HDMI when OS send monitors in sleep.
Kevin_M_Intel
Hi MaKCuMyC,
Please try changing the power options in your system. Follow the next instructions:
1. Start Menu > Power Options> Choose when to turn off the Display:
2. Click Change advanced power Settings:
3. Check for the Sleep options and configure it to never as the image shows:
4. Look for the Display option and change the configuration to Never as shown in the image:
Let me know if this works for you.
MNemi
Hello, Kevin!
Of course setting "Turn off display after" to "Never" don't brake audio stream to receiver. But it isn't solution. I can't let monitor always power up.
Kevin_M_Intel
Have you tested the configuration above but without setting the monitor to never turn off Display? Is it working fine?
MNemi
Dear Kevin, please, read first message.
If I set some number of setting "Turn off display after", then sound stops when monitor goes sleep.
Kevin_M_Intel
