22966 Discussions
Audio will not play from monitor
Fcking_Chuck
I have installed Lubuntu 23.10 on a system using an Intel Arc A770 graphics card. After the new installation, I then noticed that I couldn't hear any sound from the speakers on my television/monitor, so I tried changing displays to see if I could fix it that way. Changing devices did not work, and I still cannot hear anything despite my PulseAudio settings appearing to be fine. I believe that the graphics card may not be transmitting an audio signal to my display properly.
Here are the system's specifications:
Operating System: Lubuntu 23.10
Mainboard: Gigabyte Z790 UD AC (rev. 1.0) (BIOS version F9d)
Processor: Intel Core i5-12600KF
Memory: Kingston Fury Beast 4800MHz DDR5 8GB × 4
Graphics Card: Sparkle Intel Arc A770 Titan OC Edition - 16GB
Solid State Drive: Western Digital WD_BLACK 1TB SN770 NVMe
Monitor: Vizio 65" 4K@120Hz (Model: E65-E1) (connected via HDMI)
Andres_Intel
Hello Fcking_Chuck,
Thank you for posting on the Intel®️ communities. I will be more than happy to assist you. Since you are having audio issue with your Intel® Arc™ A770 Graphics to better understand the issue, please answer the following questions:
Andres P.
Andres_Intel
Hello Fcking_Chuck,
Were you able to run the Intel® SSU to check your system environment?
Andres P.
Andres_Intel
Hello Fcking_Chuck,
Andres P.
