23526 Discussions
BSOD in W8.1 while installing any HD4600 Drivers
MWege
this is my first post here. Here is my problem:
When i change the reserved VRAM for the IGPU Intel HD4600 to 1024MB in the Bios Settings, i can´t install any Intel HD Graphics Driver.
I have made a fresh install of WIN 8.1 and tried to install any actual Graphic Driver from every of this sources:
  • The system manufacturer's website (MSI).
  • Generic drivers provided by Intel.
  • Microsoft*'s inbox driver via Windows* Update.
But everytime at the same point of driver installation, i get an BSOD with the following message:
PAGE_FAULT_IN_NONPAGED_AREA (igdkmd64.sys)
The Basic Driver of WIN 8.1 is working. But trying to install any other Driver ends with a crash.
When i set in Bios the reserved VRAM for the IGPU Intel HD4600 to 512MB or less, i have no trouble with installing any Intel Graphic Driver.
Here are the components of my System:
MB: MSI Z97M-G43 (Actual Bios Version 1.2)
CPU: Core i3-4360
IGP: Intel HD4600
RAM: 16GB Kingston HyperX
OS: WIN 8.1 64bit
Thanks for your help
WegiMa
RS20
I can confirm this error, not only will the Intel HD Video driver on my MSI PC Mate disk not install at 1024 but their website's Z97 - Intel VGA Driver. - 2014-05-23 - 10.18.10.3540 - Win8.1 32, Win8.1 64, Win8 64, Win8 32, Win7 32, Win7 64 - intel_vga_8_mb.zip will not install or boot on win 8.1 Pro x64 at 1024. Every time I get the (Winkey) WBSOD. But it runs fine at 512 or below, and this quite obviously is not acceptable as HD4600 is a significant improvement over my other system's 4000, so I have no plans to buy another GPU. Fix us please Intel. More are on the way...
Intel Core i7-4790 Haswell 3.6GHz LGA 1150 84W Desktop Processor Intel HD Graphics 4600
MSI Z97-G41 Desktop Motherboard - Intel Z97 Express Chipset - Socket H3 LGA-1150 - ATX
Crucial Ballistix Tactical 2x2GB DDR3 1600Mhz SDRAM Memory Module
Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gbs 3.5" Internal Hard Drive
Rosewill Green RG530-S12 ATX12V & EPS12V Power Supply
Linksys E900 Wireless-N300 Router (E900)
Passmark Benchmark Score: sys-2545, cpu-10252, 2d-976, 3d-660, ram-1889, hd-1212
Jose_H_Intel1
In most cases, your computer manufacturer has already configured your computer to use the maximum amount of graphics memory that is possible for your particular model. I recommend checking with the motherboard manufacturer for the actual maximum graphics memory supported by your BIOS and whether it is possible to increase that amount.
http://www.intel.com/support/graphics/sb/CS-029090.htm Graphics — Graphics memory FAQ for Windows 2000/XP/Vista/7*
