23782 Discussions
[BUG?] Intel's Graphics Installer changes/deletes "CurrentControlSet\Control\Windows SystemDirectory" String
JSimo7
During installation Intel's Graphics driver installer changes the "SystemDirectory" string under "HKLM\SYSTEM\CurrentControlSet\Control\Windows" from "%SystemRoot%\system32" to "C:\Windows\SysWOW64". On top of that when you uninstall the driver it completely delete the string.
I'm not sure how significant changing/deleting the string is, but the string is a default part of Windows Vista/7/8.
I've attached install/uninstall logs. But it seems like a really quick fix would be to delete the following section from Setup.if2:
[Registry]
operation=create
root=HKLM
path=System\CurrentControlSet\Control\Windows
value=SystemDirectory
data=%system%
type=sz
sequence=100
group=GFX
ROBERT_U_Intel
Hi Quad5Ny
We are currently investigating the issue. Are you seeing any functional issues with your system as a result of this behavior? Could you please attach the DXDiag report for your system to this thread?
Robert
