Intel HD 4600 Graphics
File name: http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/24594/a08/win32_153614.zip&Lang=eng&Dwnldid=24594 win32_153614.zip
Version: 15.36.14.4080 (Latest)
Date: 01/12/2015
The igfxTray.exe generate an "Open File Security Warning": "The Publisher could not be verified. Are you sure you want to run this software?"
Is this file properly signed?
I also have problems when I run DPinst.exe to update this drivers. I have to uninstall earlier versions before the new version is accepted
Merlin Merlow
- Tags:
- Intel® HD Graphics
If you are getting the driver from our website then you can be sure the driver is properly signed. Just in case, here you have the download link:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24596&lang=eng&ProdId=3720 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24596&lang=eng&ProdId=3720
It is important you may encounter installation problems when using our generic driver in OEM systems so it is always recommendable to install the driver from the Computer Manufacture.
Kevin Am
