I have windows 10 and battle for middle earth 2 crashes when it wants to execute. Should I downgrade the driver? If so, how do I do it?
- « Previous
- 1
- 2
- Next »
Thank you for the clarification jk8200, this is currently under revision.
As soon as I get some feedback, will get back to you.
Esteban C
Hello, jk8200:
This is to give you with an update for the issue.
We have found some troubles while getting the game on a digital platform, for that reason, we are required to get a physical copy of the game, this will take a little longer to be achieved.
The recommendations so far are, use the drivers that were working fine while we handle this situation, also, you could try to launch the game in compatibility mode with Windows 8*
Recommendations found here:http://answers.microsoft.com/en-us/windows/forum/windows_10/windows-10-with-lord-of-the-rings-battle-for/760d961e-3b5c-470d-a070-aa3d39a2fc2e%3Fauth%3D1 http://answers.microsoft.com/en-us/windows/forum/windows_10/windows-10-with-lord-of-the-rings-battle-for/760d961e-3b5c-470d-a070-aa3d39a2fc2e?auth=1
Esteban C
Hello jk8200 ,
I just wondered if you have seen this workaround for the related issue: https://www.youtube.com/watch?v=SWQlQuHb69w https://www.youtube.com/watch?v=SWQlQuHb69w
If the problem persists, please provide me with the version of the game you are using (e.g. version 1.6 with Expansion Rise of the Witch King or without the expansion, version 1.8 with or without expansion, etc)
Hope I can hear from you positively
Esteban C
Esteban, I did try this with this config and a different one. This is required to work with every graphic driver!
Nevertheless thank you!!
Hello jk8200,
Thank you for the answer, would you please confirm if this workaround helped you. This is to get feedback and proceed accordingly (to continue handling the issue with our Graphics team).
Additionally, please provide me with the version of the game you are using (e.g. version 1.6 with Expansion Rise of the Witch King or without the expansion, version 1.8 with or without expansion, etc)
Esteban C
Esteban,
The version Im using is 1.01. Probably the crack version is only for this one given that when I updated it, it failed to work.
And the options.ini Im using is the following.
AllHealthBars = yes
AlternateMouseSetup = no
AmbientVolume = 50
AudioLOD = High
Brightness = 50
FixedStaticGameLOD = UltraHigh
FlashTutorial = 0
HasSeenLogoMovies = yes
HeatEffects = yes
IdealStaticGameLOD = Low
IsThreadedLoad = yes
MovieVolume = 70
MusicVolume = 70
Resolution = 1366 768
SFXVolume = 70
ScrollFactor = 50
TimesInGame = 84
UnitDecals = yes
UseEAX3 = no
VoiceVolume = 70
I can share with you the cd image of the game so you install it.
Let me know!
Thanks a lot for the info provided. I will sending this over for review.
As soon as I get an update, will update you as well.
Esteban C
Hello jk8200,
Would you please install the latest patch for this game and test it out?
It is required to have both the game and system updated to have the best configuration available as of now.
http://www.middleearthcenter.com/forums/downloads.php?do=file&id=412
Please let me know how it goes.
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Esteban C
For some reason, I did download the patch and eventually a crack to run with no dvd the version 1.06. It did work using the former version of the drive (as it also worked with the 1.01). But when I updated the graphics driver to 20.19.15.4483, it crashed.
Any suggestions? Perhaps in any dll?
Thanks for the answer, jk8200
I just want to confirm, have you tested the behavior of the latest drivers while using the latest patch?
I look forward to your reply.
Esteban C
Hello jk8200,
I would like to verify if you were able to check and proceed with the last answer above.
Esteban C
is there a video of how we can make bfme 2 work? screenshots would be fine too even though i'd have a more hard time figuring everything out 😕 i don't know much about these stuffs,i tried searching on youtube about a solution but i only found solutions about other things,thanks Esteban C
Hello Fairy ,
Do you have the latest patch installed for this game?
Here you can find and download the patch: http://www.middleearthcenter.com/forums/downloads.php?do=file&id=412 http://www.middleearthcenter.com/forums/downloads.php?do=file&id=412
Additionally, do you have the Intel HD Graphics on your device updated?
Here the beta driver 4539: https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
Please note older Intel HD Graphics may not work with this driver, supported adapters (Intel HD Graphics) can be found in the "Release notes (pdf)" link in the download page.
Let me know how it goes
Esteban C
I believe I have the same problem as jk8200 due to the HD Graphics
However, he says he can get the game to work with the 15.36.3.64.3907 driver. For some reason I can't install it (when I try to do so, I'm told that I already have the best version installed) and I'm not sure how to force the installation.
Thank you for your help.
Hello Neric007,
Please try the following:
1. Access the device manager and look for display adapters
2. Right click and uninstall the driver, make sure to select "Delete the driver software for this device"
3. Download the driver
4. Open this link: for Windows 10/8: http://intel.ly/1PdmvLd http://intel.ly/1PdmvLd or Windows 7*: http://intel.ly/25JPVYX http://intel.ly/25JPVYX
5. Disconnect the system from the internet and proceed with steps in the guide above (step# 4)
Esteban C
I have been trying to get bfme2 and rotwk working for ages and cannot get it working. I have a intel core i5 6200u 2.30ghz, intel hd graphics 520
I have the options ini file, all update patches etc from downloads. Is it more likely its my graphics card? or do i need to install a specific driver?
what a nightmare it is to play an old game.
Thanks for any help.
- « Previous
- 1
- 2
- Next »
