23087 Discussions
Battle for middle earth 2 and windows 10 can work?
JKara3
I have windows 10 and battle for middle earth 2 crashes when it wants to execute. Should I downgrade the driver? If so, how do I do it?
EstebanA_C_Intel
Hello, jk8200:
Please check this link related to compatibility with Windows 10*
It would guide you on how to use the compatibility troubleshooting for Windows 10*
https://techingiteasy.wordpress.com/2013/07/08/using-compatibility-mode-in-windows-8-1/ Using Compatibility Mode in Windows 8.1 | Teching It Easy: with Windows
Esteban C
JKara3
Esteban!
Already did this!
The issue is that battle for middle earth 1 works, while the BFME2 doesn't.
With this compatibility mode done previously.
Is there a driver that is compatible with windows 10 and that can work with Windows XP software?
EstebanA_C_Intel
Hello, jk8200:
I understand, I read some articles regarding this and the option you requested (downgrade the driver) as a possible workaround to get this to work.
To do this, you would only need to access https://downloadcenter.intel.com/ Drivers & Software
Type the HD Graphics that are in your system (depends on the processor).
After you find this, it would be to test the system with older Windows 10* drivers that have been released.
How to check HD Graphics present?
1. Look for the processor that you have.
2. Find it here http://ark.intel.com/ ARK | Your Source for Intel® Product Specifications
3. Look fro Graphics Specifications
Esteban C
JKara3
Esteban, I tried running this, Intel I7 4th generation 4600U, and controller version of the graphics driver is 10.18.15.4281
The software you suggested only goes by if used by the Dell system!
EstebanA_C_Intel
Hello, jk8200:
Here you can find the drivers that are available for Windows 10* 64-bit for the Intel® HD Graphics 4400 that are present in the Intel® Core™ i7-4600U Processor.
https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
https://downloadcenter.intel.com/download/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit Download Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows® 10 64-bit
https://downloadcenter.intel.com/download/25308/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
Windows 10* 32-bit:
https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
If you are using an OEM system, the recommendation is to download and install the drivers from your computer's manufacturer website.
This is to avoid loosing any special features or settings while using the generic drivers from Intel®.
Please do check with them if this is your case, different drivers could be available with them.
If you require any further information or support, feel free to contact us back.
Esteban C
JKara3
Esteban, como va todo?
Estoy teniendo el problema siguiente. La constante necesidad de actualizar la placa de graficos hace que el juego no pueda correr. Con la version Driver Version: 15.36.3.64.3907 va excelente.
Que diferencia hay con la version 20.19.15.4390 que es la ultima que tengo ya que se actualizó de forma automatica?
Debe haber alguna cuestion que hace que el juego no pueda correr. Y con esta cuestion solucionada podría funcionar perfectamente.
Gracias!
EstebanA_C_Intel
Hey, jk8200:
I've been good, thanks for asking, hope you are doing well too
Alright, that seems odd (the previous driver working and newer not working so well).
Have you tested the latest drivers released by Intel?
Here the drivers mentioned:
Beta 15.40.26.4474 // https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
15.40.25.4463 // https://downloadcenter.intel.com/download/26078/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
Please check them out and let us know how the gameplay is.
Esteban C
JKara3
Esteban, unfortunately Windows did not recognize any of the links even though I could download them but it said it could not execute them.
I can only make it work with the version of graphics I mentioned before.
The one I currently have is the version 20.19.15.4390 which doesnt allow me to execute the game. So I have to install the other one when I want to play.
Please let me know what is missing in the one I have that the other one included so as to make the difference.
EstebanA_C_Intel
jk8200:
Please follow this method to install the drivers (both beta and latest)
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html How to Manually Install an Intel® Graphics Driver in Windows® 10 &...
Perform the testing with the game and provide me with some feedback about how it went.
Esteban C
JKara3
Esteban, pude instalar el primero y no resulto.
El segundo me dice que estando el actual instalado (con el que funciona el juego del 2014), no toma al segundo link.
Seguimos probando!
Gracias!
EstebanA_C_Intel
Thank you for your quick answer, so 4463 is not working? what is the error message that you received? May I have a screenshot of that?
Esteban C
JKara3
So, I now have the version 20.19.15.4331, and when trying to install the version you suggest, a window saying that the package is not compatible with the processor.
The only solution Im finding is to re install the version I use when I want the game to play but it keeps installing newer versions.
EstebanA_C_Intel
jk8200:
Would like to check, were you able to use the manual installation advised before?
Additionally, It would be good to disconnect the device from the internet before installing the driver manually.
This is for 4463, I am positive you can install the driver.
https://downloadcenter.intel.com/download/26079/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81497 Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
Please let me know how it goes.
Esteban C
JKara3
So! I could install both versions! In the 64 bit, it didnt work. It happens the same thing that with the last version, it just crashes. And the 32 bit was rejected from the setup saying that it is not compatible with the processor.
EstebanA_C_Intel
Hi, jk8200 :
I see, so we have tested different drivers so far, I was wondering, have you tried installing the game again? This is to discard any possible corrupted file during its installation.
Additionally, have you tested this with the basic windows drivers? You can get them after removing the drivers from the device manager.
Please select the option noted below while doing this.
Esteban C
Hello, jk8200:
I was wondering if you were able to follow the recommendations in my last answer.
Please let me know.
Esteban C
JKara3
Esteban, for some reason I dont think it is within the game or that something went corrupt.
I dont know why with the driver I mentioned, it works well and with other versions it crashes.
I might get used to the one I have given that it works and doesnt give me any problem!
JKara3
Esteban, just for the fact, I uninstalled the game and the drivers. I installed the game again, and with the microsoft driver, it worked but went slow. After I enabled wifi again, the system looked for the driver which is currently installed, 20.19.15.4331, and when executing it, it crashed. Trying to run the one you suggested now. Will see again if it works.
Hello, jk8200:
Thank you for the answer provided! I just would like to verify, is the driver version: 15.36.3.64.3907 the one that is not giving the issue in your system?
I will be checking this thread for the outcome of your testings as well as the confirmation of the drivers that were working fine.
Esteban C
JKara3
Esteban, the one working well is the 10.18.10.3907!
Best regards!
