23102 Discussions
Best settings to use for BENQ GL2440HM
I have just purchased a Benq GL2440HM LED monitor for use with a Dell XP SP3 PC.
Could someone advise me please what the best settings/driver to use for this monitor?
I have the monitor set at present for 1280x768 but this gives a rather poor display. Other settings give a crisper display but the aspect ratio is lost and the display has a squashed appearance. Is there anything I can do to get the best out of the monitor?
The report below details what I currently have.
Chris
INTEL(R) EXTREME GRAPHICS 2 REPORT
Report Date: 05/23/2011
Report Time[hr:mm:ss]: 09:24:32
Driver Version: 6.14.10.4396
Operating System: Windows XP* Home Edition, Service Pack 3 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 2045 MB
Minimum Graphics Memory: 1 MB
Maximum Graphics Memory: 96 MB
Graphics Memory in Use: 7 MB
Processor: x86
Processor Speed: 2992 MHZ
Vendor ID: 8086
Device ID: 2572
Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel(R) 82865G Graphics Controller
Video BIOS: 2972
Current Graphics Mode: 1280 by 768 True Color (75 Hz)
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
* Monitor *
Monitor Name: Plug and Play Monitor
Display Type: Analog
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 20.8 inches
Vertical: 11.8 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (60 Hz)
800 by 600 (75 Hz)
832 by 624 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (75 Hz)
1152 by 870 (75 Hz)
1280 by 720 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
1280 by 1280 (60 Hz)
1600 by 900 (60 Hz)
1680 by 1680 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
