23774 Discussions
Black Screen when changing settings on Intel Graphics Command Center
ableabh
I am using a Dell Latitude 5400. Changing any settings from the display tab inside Intel Graphics Command Center like contrast, saturation and hue results in a black screen. This has been reported previously also by others so seems like a common issue which should be fixed.
I can restore the Display only by connecting it to an external monitor and uninstalling the graphics driver, but right now I don't even have an external monitor so afraid to make any changes.
I really want to use the Graphics Command Center because the display appears a bit dull.
Drivers: Intel UHD Graphics 620 (v27.20.100.9126)
GCC version: 1.100.3282.0
Intel® Graphics Command Center Feedback
David_G_Intel
Hello ableabh
Thank you for posting on the Intel️® communities.
Please share with us the following information:
  • When did this issue start?
  • Does this happen with different driver versions?
    • If you tested different drivers, please list their version.
  • Did this start after an OS (or driver) update?
  • Windows version and build
  • Does this happen with both Intel and Dell drivers?
  • Provide the Intel® System Support Utility (Intel® SSU)
    •  Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
    • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
    • Click on the menu where it says "Summary" to change to "Detailed View".
    • To save your scan, click on "Next", then "Save".
If you can, please share a video with us to get a better understanding of the problem.
David G
Intel Customer Support Technician
David_G_Intel
Hello ableabh
David G
David_G_Intel
Hello ableabh
David G.
