23272 Discussions
Black flickering balks
MDona4
Hi i have a intel 4400 and since a graphik update i cant play anymore games because of black flickering balks. I already contacted the Intel support but they did not have a answer. My problem is i have black flickering balks with the common intel settings(game is cs:go). There is a solution but this is not a good one. If i install the old driver when i bought my laptop it woks but then i just have 18 Fps. Pls help me guys.
Here are all informations you need:
# SSU Scan Information
Scan Info:
Version:"2.5.0.12"
Date:"12.22.2017"
Time:"00:00:36.3639920"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Acer"
BIOS Mode:"UEFI"
BIOS Version/Date:"Insyde Corp. V2.01 , 09/16/2013"
CD or DVD:"Not Available"
Embedded Controller Version:"2.1"
Platform Role:"Mobile"
Processor:"Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"2.7"
Sound Card:"High Definition Audio-Gerät"
System Manufacturer:"Acer"
System Model:"Aspire R7-572"
System SKU:"Aspire R7-572_0815_V2.01"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"10.18.15.4248"
- "Intel(R) HD Graphics Family"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) HD Graphics Family"
Link:" http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+Family"
CoInstallers:"oem19.inf,iHSWM_w10,Internal,Intel(R) HD Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"06.28.2015 05:00"
Driver Path:"C:\WINDOWS\system32\DRIVERS\igdkmd64.sys"
Driver Provider:"Intel Corporation"
INF:"oem19.inf"
INF Section:"iHSWM_w10"
Install Date:"Not Available"
Installed Drivers:"igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_0A16&SUBSYS_08151025&REV_09\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"60 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) HD Graphics Family"
- "Memory"
Physical Memory (Available):"4,97 GB"
Physical Memory (Installed):"8 GB"
Physical Memory (Total):"7,88 GB"
- "BANK 0"
Capacity:"4 GB"
Channel:"DIMM0"
Configured Clock Speed:"1600 MHz"
Configured Voltage:"Not Available"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"First position"
Manufacturer:"Kingston"
Maximum Voltage:"Not Available"
Memory Type:"DDR3"
Minimum Voltage:"Not Available"
Part Number:"ACR16D3LS1NGG/4G"
Serial Number:"342E689B"
Status:"Not Available"
Type:"Synchronous"
- "BANK 2"
Capacity:"4 GB"
Channel:"DIMM2"
Interleave Position:"Second position"
Memory Type:"DDR3"
Serial Number:"332E789B"
Type:"Synchronous"
- "Motherboard"
BIOS:"V2.01, ACRSYS - 1"
Caption:"Hauptplatine"
Chipset:"Not Available"
Date:"09.15.2013 05:00"
Install Date...
Stefan3D
Try drivers from this list, select your OS in right pulldown menu
https://downloadcenter.intel.com/de/product/97500/Grafik-f-r-vierte-Generation-der-Intel-Core-Prozessoren Downloads für Grafik für vierte Generation der Intel® Core™ Prozessoren
If you encounter an error message about validation, then install driver via "have disk method" as described at:
www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
MDona4
No i still have flickering black balks in cs:go. But thank you for your help.
MDona4
I found the problem. Everyone who has the same problem try this:
Click at the first button.
Then rightclick on csgo and click the last button.
Then click the button where the check mark is and activate it. Now i have no more issuses.
I hope i can help u.
