23834 Discussions
BlueStacks Screen Flickering Bug Fix?
MDude1
Hey everybody, I have a big question that I have to ask you guys. Normally I can find the answer relatively easily to things like this, however this one is stumping me.
While using BlueStacks App Player, more specifically Clash of Clans, I get a strange bug where some entities begin to flicker, I do not know the origins of this bug for dell computers, I was easily able to fix a similar issue on my old laptop, which ran a NVIDIA graphics card, but this Intel one just doesn't have the same adaptability in the properties interface as the old one.
In the Device Manager, when looking at the Display Adapter section, this is what pops up, I also have other windows open to see if maybe it would help you to solve the problem.
I have a video of what is happening also if you don't already know what it is like.
It isn't very noticeable in this video, but it is old, and it is really bad now.
Thanks in advance,
Mayson
Jose_H_Intel1
Jose_H_Intel1
You may want to try https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3712&DwnldID=23714 the latest Intel® HD Graphics driver.
MDude1
For the most part, this has solved the issue. The issue is still not 100%, but I give it a 95% reduction.
I don't expect an emulation to run at 100%, especially when running games like Clash of Clans, so I give this issue a "Solved" Check mark.
MDude1
Well, it worked for all of 15 seconds. The issue is back even after updating.
I'll try it again, and see if there were issues with the installation, I was accidentally almost trying to do it twice, which may have caused issues.
MDude1
There was just an issue with the first installation. The problem is fixed for now.
PKuma46
Hii friends....If you are having a laptop using Nvidia Optimus technology then you can run games like clash of clans or any other without having any black screen or flickering issues in Bluestacks anymore...So just follow the below given tutorial...
http://www.rushinformation.com/clash-of-clans-black-screen-bluestacks-fix/ http://www.rushinformation.com/clash-of-clans-black-screen-bluestacks-fix/
