22881 Discussions
Boa tarde! Sabem me informar se a placa de vídeo Intel® UHD Graphics 620 Integrada tem suporte para os recursos: True Color, Direct X11 e Shader Model 3? Desde já agradeço. Preciso para rodar alguns programas relacionados a arquitetura.
RRola5
OS PROGRAMAS SÃO: REVIT 2017, AUTOCAD 2018 E SKETCHUP 2018.
Wanner_G_Intel
Hello RRola5,
Thank you for submitting your question on this Intel® Community.
To better assist you, please provide us with the following information:
DxDiag* report
  1. Go to Start > Run or Windows Key + R.
  2. On the Run prompt, type "dxdiag" then click OK.
  3. On the DirectX Diagnostic Tool window, click on Save All Information.
  4. Browse to a folder, type in a filename then click Save.
Note: Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded on this Intel® Community.
Wanner G.
RRola5
Boa tarde!
Obrigado por seu retorno.
Não tenho essa placa de vídeo em nenhuma máquina ainda, mas queria saber se ela tem capacidade para rodar os programas relacionados a minha faculdade de arquitetura (AUTOCAD 2018, REVIT 2017 e SKETCHUP 2018). Desde já agradeço!
Wanner_G_Intel
Hello RRola5,
Thank you for your response.
Intel® UHD Graphics supports DirectX* 12. It is backward compatible, so it should work with DirectX* 11.
True Color, also known as 8-bit, is also supported.
Shader Model 5.1 is supported by this graphics controller, so it should support Shader Model 3.
I hope you find this information helpful.
Wanner G.
Wanner_G_Intel
Hello RRola5,
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
A Contingent Worker at Intel
Wanner_G_Intel
Hello RRola5,
We have not heard back from you, so we will close this thread.
If you need further assistance, please submit a new question, we will be glad to help you.
Wanner G.
