23091 Discussions
Both monitors blank at startup, only when HDMI monitor connected g45/g43 chipset
HDer
Gateway DX4820-20c 6 months ago. Windows 7 Ultimate OS, 6G Ram. Has G45/43 intel graphics onboard chipset. VGA and HDMI output. HDMI configured as primary, VGA as secondary, extended setup. Updated all Intel drivers including video driver. HDMI monitor is Toshiba 40" TV - VGA monitor is FHX2300. This is what happens:
1) VGA monitor connected only - startup is fine, display works.
2) VGA and HDMI connected - both monitors blank
3) HDMI connected only - monitor blank
4) VGA monitor connected only - startup OK, then connect HDMI, then HDMI comes on, and both work fine.
This is the only way I can get both to work. Unplug HDMI, start with VGA, wait for bootup, then connect HDMI.
5) reconfigure VGA primary, HDMI secondary - same problem occurs.
Other computer system can bootup and display with HDMI monitor connected, but not this Gateway system...?
Thanks for any solutions/suggestions.
BPopl
Almost the identical issue here! Using the onboard VGA and HDMI on a Dell Inspiron 3000. This exact setup worked on the older system, upgraded system.....Black screen at boot! All the options have been gone through just like henryder,,,,now I am going to have get the client a video card to do it and it makes no sense!
Jose_H_Intel1
It may help clarifying if you get no video during POST, operating system boot, or both.
Do you get video at the moment the desktop is loaded?
It may be a good idea to update the BIOS.
