23266 Discussions
Brightness drops to 10% after upgrading to W8 (Intel HD 3000)
Hi, I recently upgraded my laptop to Windows 8. The day after the brightness suddenly dropped to 10%.
After adjusting the slider back up, the brightness immediately drops to 10% again. With some luck the brightness may not drop back down to 10% for a few minutes. But usually it's a matter of seconds (or even immediately).
Windows says the Intel HD 3000 drivers are all up to date.
The problem occurs on different networks (at university, at home,...)
Is there a solution to this problem??
OS Name Microsoft Windows 8 Pro
Version 6.2.9200 Build 9200
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name ONAWA-VAIO
System Manufacturer Sony Corporation
System Model VPCCA4E1E
System Type x64-based PC
System SKU N/A
Processor Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz, 2300 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. R2110V2, 27/09/2011
SMBIOS Version 2.7
Embedded Controller Version 21.10
BIOS Mode Legacy
BaseBoard Manufacturer Sony Corporation
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Mobile
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale Belgium
Hardware Abstraction Layer Version = "6.2.9200.16442"
Username ONAWA-VAIO\ONAWA
Time Zone Romance Standard Time
Installed Physical Memory (RAM) 4,00 GB
Total Physical Memory 3,91 GB
Available Physical Memory 1,84 GB
Total Virtual Memory 7,91 GB
Available Virtual Memory 5,29 GB
Page File Space 4,00 GB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
Name Intel(R) HD Graphics 3000
PNP Device ID PCI\VEN_8086&DEV_0116&SUBSYS_9081104D&REV_09\3&11583659&0&10
Adapter Type Intel(R) HD Graphics Family, Intel Corporation compatible
Adapter Description Intel(R) HD Graphics 3000
Adapter RAM 1,77 GB (1.899.606.016 bytes)
Installed Drivers igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver Version 9.17.10.2828
INF File oem24.inf (iSNBM0 section)
Colour Planes Not Available
Colour Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Memory Address 0xF5000000-0xF53FFFFF
Memory Address 0xE0000000-0xEFFFFFFF
I/O Port 0x0000E000-0x0000E03F
IRQ Channel IRQ 4294967293
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\igdkmd64.sys (9.17.10.2828, 8,57 MB (8.987.456 bytes), 24/08/2012 0:12)
Marcos_U_Intel
Hello Stefaan Leleu,
I recommend you get the latest graphics driver at the link below:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22083&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
Bear in mind our Intel graphics drivers are generics, so if the issue continues then try the graphics driver from your system manufacturer, or you might have to do a clean installation of Microsoft* Windows* 8, instead of an upgrade.
Ragards,
Michael
