23751 Discussions
ig4icd32 exception
Rocketbirds Hardboiled Chicken fails to launch on windows xp (6.14.10.5420 gma driver)
<<<<<<<<<<<<<<< UNHANDLED EXCEPTION OCCURED >>>>>>>>>>>>>
001B:09839478 (0x001C4EA4 0x0012D360 0x00000004 0x00000077) ig4icd32.dll
001B:0983AF1D (0x013D4E1C 0x001C4EA4 0x19331B80 0x001C007F) ig4icd32.dll
001B:09705495 (0x09963B30 0x09962860 0x09963B90 0x096B08D0) ig4icd32.dll
NICHOLAS_F_Intel
Hi r-r,
Can you provide your dxdiag so I can take a look at your system specs? (Start -> Run -> dxdiag -> Save All Information).
Thank you,
-Nic
System Information
Time of this report: 11/29/2012, 00:07:03
Machine name: 2-513
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.120821-1629)
Language: English (Regional Setting: Russian)
System Manufacturer: MICRO-STAR INTERNATIONAL CO.,LTD
System Model: MS-7521
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz (2 CPUs)
Memory: 3294MB RAM
Page File: 1329MB used, 1795MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) G45/G43 Express Chipset
Manufacturer: Intel Corporation
Chip type: Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2E22&SUBSYS_75211462&REV_03
Display Memory: 1024.0 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor: Philips 244E (24inch WIDE LCD MONITOR 244E1)
Monitor Max Res: 1920,1080
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.5420 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/28/2012 18:34:36, 58368 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 8/28/2012 18:34:36, 2019200 bytes
Device Identifier: {D7B78E66-6D62-11CF-FE62-2B55A2C2CB35}
Vendor ID: 0x8086
Device ID: 0x2E22
SubSys ID: 0x75211462
Revision ID: 0x0003
Revision ID: 0x0003
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_14627521&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5832 (English)
WHQL Logo'd: Yes
Date and Size: 4/14/2009 16:09:56, 5069312 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 31
Static/Strm HW 3D Bufs: 33, 31
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Controller (Gamepad F310)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC21D
FF Driver: n/a
Device Name: USB Multimedia Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC31A
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3A37
| Matching D...
NICHOLAS_F_Intel
Thanks for providing that info. It looks like you need to update your driver. I'm unable to navigate MSI's website to see if they have one available, or even provide one. Go ahead and give ours a try though unless you know of a way to get it from MSI!
Here's the link for the most up-to-date driver for your system; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21828&lang=eng&OSVersion=Windows%20XP%20%20*&DownloadType=Drivers Download Center
Install it, give it a try - and let me know if you're still experiencing the same issue.
-Nic
it is the latest driver
Display Devices
DAC type: Internal
WHQL Logo'd: Yes
VDD: n/a
NICHOLAS_F_Intel
You're right! Sorry I didn't catch that.
Can you provide me more information on when this error is occurring? During the games start up, in the middle of play, some other point?
-Nic
