23092 Discussions
[Bug Report] GLSL macro causes glsl-compiler freeze
OS: Win7 64bit
Renderer info:
GL_VENDOR:Intel
GL_RENDERER:Intel(R) HD Graphics 3000
GL_VERSION:3.1.0 - Build 8.15.10.2761
Description:
Thread never returns from call to glCompileShader.
Code:
//Compiler freezes
std::string macros =
"# version 130\r\n"
"# define TEST_MACRO(X) uniform sampler2D agent_# X\r\n";
std::string source =
"TEST_MACRO(text0);\r\n";
gl::GLint shader = gl::glCreateShader(gl::GL_VERTEX_SHADER);
const char* sources[] = {macros.c_str(), source.c_str()};
gl::GLint lens[] = {macros.size(),source.size()};
gl::glShaderSource(shader,2,sources,lens);
gl::glCompileShader(shader);
Other similar problem:
Description:
Very similar code results compiling error, even thou I think that glsl-shader code is valid.
According to http://www.opengl.org/wiki/GLSL_Object# Shader_compiling http://www.opengl.org/wiki/GLSL_Object# Shader_compiling glShaderSource should work like string given to it are combined.
GLSL code will compile if both source strings are combined before giving them to compiler.
Code:
//Compile fail
"# version 130\r\n"
"# define TEST_MACRO(X) uniform sampler2D agent_# X; uniform vec4 agent_# X# _atlas_rect\r\n";
//Log:
//ERROR: 1:2: 'uniform' : no qualifiers allowed for function return
//ERROR: 1:2: 'text0' : syntax error syntax error
