22946 Discussions
Building a NAS, trying to decide if I want Q45 with ICH10R or ICH10DO SB
These are the features each has that the other doesn't...
ICH10R:
Intel Turbo Memory Support
Wake on VoIP
Intel Viiv Processor Technology Support
Intel RWT
ICH10DO:
Intel Active Management Technology [Release 5: Pro]
Intel Trusted Platform Module
JTAG Boundary Scan
I think the only features that "may" be of use from either is: Turbo Memory Support, Active Management Technology.
I've read-up on most of the features listed but still can't decide which SB I want/need more, any suggestions anyone?!
Cheers
Jed
The ark tool is useless
http://ark.intel.com/Compare.aspx?ids=34394,34395,
it reckons the two SB's are exactly the same, contrary to ICH10 family datasheet
http://www.intel.com/assets/pdf/datasheet/319973.pdf
This is a better compare listing:
http://www.intel.com/support/chipsets/imsm/sb/CS-022304.htm http://www.intel.com/support/chipsets/imsm/sb/CS-022304.htm
The ICH10DO has Capacity expansion should you wish to add drives to the array later for more storage.
Thanks, but this is only the differences in relation to "matrix storage tech" which is one major componant of these controllers...
I'm ultimately trying to decide if I need the Q45 w/ICH10DO or G45 w/ICH10R
The main use initially is for NAS/fileserver etc, but longer-term I may want to repurpose it as a HTPC....
These are the main difference I;ve been able to ascertain so far...
http://communities.intel.com/message/51414# 51414
Could I get away with a Q45 w/ICH10DO as a base for HTPC? It doesn't have X4500HD (Intel CVT)
Nothing stopping you from adding a graphic card later...
mods feel free to delete, ive incporporated all questions in this thread into:
