22898 Discussions
Can Intel(R) HD Graphics 520 support dual monitor display?
Kiranssk
Hii all!
i have a intel HD 520 graphic card but i dnt knw if it supports dual monitor setup or not, because when i tried setting it up i couldn't it didn't detect the second display
And for details My Pc has Intel(R) Pentium(R) CPU G4400 @ 3.30GHz 3.31 GHz Processor with RAM of 4.00 Gb
Thank You.
n_scott_pearson
We need more information. Please download and run the Intel System Support Utility for Windows. Select all data categories, generate the report and then have the tool save the report to a file. Don't try to use the Submit capability; it doesn't work currently. Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
