23586 Discussions
Can Intel® UHD Graphics 770 Integrated graphics output a single 4k120hz?
anotherdev
I'm looking to getting a N100 processor-based miniPC. The cpus were released Q1 2023.
The spec sheet says maximum resolution is 4K60hz * 3 (three outputs)
4K Support -Yes, at 60Hz
Graphics Output eDP 1.4b, DP 1.4, HDMI 2.1, MIPI-DSI 1.3
Max Resolution (HDMI)‡4096 x 2160@60Hz
Max Resolution (DP)‡4096 x 2160@60Hz
# of Displays Supported ‡3
I know that 4k120hz requires bandwidth 25.82Gbit/s so I need to use HDMI 2.1 (42.6 Gbit/s) or DP 1.4 (25.92Gbit/s) cables.
If I only use 1 output instead of all 3, will the iGPU be powerful enough to output the maximum supported output of my connected TV (4k120)?
There is a similar question but they're asking about lower res (2k) higher refresh (144hz) for UHD 550 -- and it worked great. So I assume it will work.
Looking for conformation. Thanks
anotherdev
The miniPC I bought finally arrived and after testing, Success!
Contrary to the official reply above:
the Intel® UHD Graphics 770 Integrated graphics inside a 12TH Intel Alderlake-N N100 CPU
CAN INDEED output at 4k120hz via the DisplayPort 1.4 output.
My use case:
  1. SIMODEWA MiniPC DP 1.4 outputting @ 4k120
  2. Cable used is ULT-WIIQ 8K@60Hz DisplayPort to HDMI Adapter via Amazon UK £28
  3. HDMI 2.1 converted output end goes into LG TV
MUC
Honored Contributor I
If you'd buy an Intel NUC with Iris Xe then you can get 4K @ 120 Hz with an active USB-C/Thunderbolt > HDMI cable.
See this: community.intel.com/t5/Intel-NUCs/Do-Intel-NUC-11-12-13-support-4K-UltraHD-144Hz/m-p/1507122#M101872
Jean_Intel
Hello anotherdev,
Thank you for posting in the Intel Communities. To better answer your question about the support for 4k120hz when using the Intel® UHD Graphics (Intel® Processor N100), we would like to look into this matter internally. We will post back as soon as we have further details.
Jean O.
Jean_Intel
Hello anotherdev,
Thank you for your patience. Based on the processor specifications, the maximum resolution is 4K@60Hz. In case you prefer to have a 120Hz refresh rate, then the resolution must be lowered according to supported resolutions and refresh rate in preferences.
Jean O.
Jean_Intel
Hello anotherdev,
We hope you are doing fine.
We have not heard back from you, so we will close this thread. If you need additional information, submit a new question since this thread will no longer be monitored.
Best regards.
Jean O.
anotherdev
My use case:
MUC
That's a positive surprise!
The specs suggested that N100 couldn't do that. Thank you for the feedback, very interesting.
By the way: The ULT-WIIQ 8K@60Hz DisplayPort to HDMI Adapter contains the Synaptics VMM7100 protocol converter. This is the most stable solution so far.
