22862 Discussions
Can The HD 4000 support 3440*1440 resolution via dp 1.1 or HDMI 1.4 ?
祺马
Hello ! I found the 2012 mba support 3440*1440@50hz via thunderbolt,with HD 4000. So, can clevo p150em support 21:9 display via these port ? thks 😛
Hello Deemax,
Thank you for contacting Intel Communities.
In this case, the laptop you have comes with dedicated graphics (Intel and NVIDIA), from Intel's side, for max supported resolutions you can check the following:
/message/246467# 246467 Re: Intel HD 4000 HDMI 2560x1440 resolution???
To see the post in context you can check the following thread:
/thread/30360 Intel HD 4000 HDMI 2560x1440 resolution???
You can also check the following article for further information:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005529.html Frequently Asked Questions about Display Resolutions.
At this point, the best recommendation is to contact the system manufacturer as The resolutions available on each video port are limited by them.
Hope this information helps.
Juan Carlos
Hello Deemax,
Juan Carlos
祺马
Thank you so much !I have found the problem i can modify the resolution but cant apply.if we select "CVT-RB" as Timing Standard, 2560x1440 @ 55 Hz is possible,3440*1440 too(54Hz) .But, it did not appear in the Windows dialog until you rebooted the computer.Everything is clear now 😛 THKS
Hello Deemax,
I am glad to know I was able to answer your questions.
Don't hesitate in contacting us again if you need further assistance.
Juan Carlos
