23282 Discussions
Can't Install drivers for Intel HD 4000 graphics.
TDing
I had to uninstall my Intel HD 4000 graphics due to an issue where games would not run for some unknown reason related to the graphics update I did. I uninstalled it via the device manager and uninstalled the HD audio as well. I restarted my laptop and it recognizes the graphics card as an unknown video controllerd (VGA compatible) in which whenever i try and update via the device manager it just tells me there is a problem and to contact the manufacturer and aborts the update.
I then downloaded the latest drivers off of the website for my Intel HD 4000 graphics card and whenever I run it, half way through the installation it either says the OS isn't supported, one or more drivers failed to install or that I do not meet the minimum requirements to install this driver. I use a Nvidia 640m GPU also which seems to still be working perfectly, but the Intel HD 4000 graphics card will now not re install and I don't know what to do to fix it.
ACorr7
I need this driver too, bit it says "page not found" with the 64 bit
CYild
that is the 32 bit version. for me it says that the driver is not validated for my system, and to get the driver from the manufacturer, but I want the latest driver.
ROBERT_U_Intel
