23641 Discussions
Can't Install the Latest Graphics Driver Update
IFred
I have an Intel 4600 on Windows 10, and I wanted to install the latest driver update to try to fix some issues with sudden lag in World of Warcraft and Star Wars: The Old Republic. I went to this link https://downloadcenter.intel.com/download/26079/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen] to get the latest driver. When I try to install it, it takes a while, and it pulls up my file explorer. I don't know what to do from there to download the driver.
Stefan3D
Usually it opens explorer when downloading the ZIP version.
Download the EXE version instead.
IFred
When I tried downloading it with the top button, (which I assume is the EXE version,) it said "This Driver being installed is not validated for this computer."
IFred
I need to install the ZIP version, but I don't know how and the instructions aren't clear.
Stefan3D
Try this tutorial: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html How to Manually Install an Intel® Graphics Driver in Windows® 10 &...
IFred
I found those instructions, and I clicked on this link. http://www.intel.com/content/www/us/en/support/graphics-drivers/000005488.html How to Get ZIP Version of Intel® Graphics Driver
I'm stuck on step 14, "Select the folder to save a copy of the ZiP file." I don't know how to select a folder.
Stefan3D
You don't don't need to select a folder.
Windows or in this case your browser store by default downloads in a folder named "Downloads".
In Explorer you find that on the left side under fast access.
Hi all,
Thanks Stefan3D, Masterfcards Could you please attach the result of the Intel® System Support Utility?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Hellen.
IFred
But then what about the next step, "Click save to begin the copy." I can't find the button.
IFred
Thank you, Hellen, but I don't see why I need to download that. All I want is to update my driver with the ZIP version. I don't need a scan
Hi Masterofcards,
The scan is to collect more information about your system, because if it is a prebuilt system I would recommend you to install the graphics driver provide by the manufacturer, instead of the generic.
Please follow these steps in order to install the ZIP the generic driver version:
1-Download the zip file of the driver from download center, unzip and keep file in the desktop.
2-Turn Internet connection off
3-Go to device manager>Display Adapter, right click Intel HD graphics and select uninstall driver (check delete box)
4-Restart the computer
5-Go to device manager> Display Adapter, right click over Microsoft generic driver select Update driver, browse search.
Hellen.
IFred
It is a prebuilt system. I want to install the generic version because I am having lagging issues with games, and I also often get an error message saying "This application has been blocked from accessing graphics hardware." I was told on the Windows 10 forums that I needed to update my drivers. Anyway, thank you, and I'll try these steps!
IFred
I tried to install it, but I don't know how to "unzip." What button does that?
Stefan3D
In Explorer click right mouse button when pointer is over the ZIP file, then select "extract all" from menu popping up.
Hi Masterofcards,
I would like to know if you were able to install the driver.
Hellen.
IFred
Well, I updated the driver, but the lagging still happens.
Hi Masterofcards,
In order to collect more information about your system, Could you please attach the result of the Intel® System Support Utility?
I recommend you to check on this Intel website, to get optimized game settings that have been created to provide you with the best gaming experience on Intel Graphics.*
https://gameplay.intel.com/ https://gameplay.intel.com/
Hope this helps you.
Hellen.
IFred
Sorry I didn't respond in a while, but the problem is that my computer overheats.
Hi Masterofcards,
Please follow these troubleshooting steps for overheating issues:
http://www.intel.com/content/www/us/en/support/processors/000005776.html http://www.intel.com/content/www/us/en/support/processors/000005776.html
Hope this helps.
Hellen.
